XJ40 ( XJ81 ) 1986 - 1994
no start issue
Old Dec 8, 2018 | 01:40 PM
91calijag's Avatar
Default no start issue
I am diagnosing a crank, no start issue. The crank sensor checked ok. Fuel pressure checks ok. The injectors are working because I definitely smell fuel, as if it were flooding. I have a weak/no spark. I am ohm'ing the coil which is reading higher than what is the norm....8.9 on the 20k ohm scale, versus 6k ohm, which is what it is suppose to read, plus or minus 10%. Im also getting a .9 ohm reading between the positive and negative coil terminals, where it is suppose to be .5 ohms.
I am getting 12V at the positive coil terminal which tells me the ignition relay and ignition amplifier/module are good. Not to mention the amplifier is about a year old.
Any thoughts?? Im probably going to replace the coil.
No check engine light.
Thanks,
Old Dec 10, 2018 | 05:30 PM
sanchez's Avatar
My 2 cents.
Check out the distributor cap and rotor. Rotor is known to fail. Temporary fix is to remove the rotor and apply some grease to the shaft where the rotor goes and see if it fires up.
Old Dec 10, 2018 | 06:40 PM
91calijag's Avatar
Ill give it a shot. I'm actually gonna buy a new cap and rotor. I am getting spark to the plugs though so that tells me the rotor is working. Only hope is that the current rotor and cap aren't giving it enough juice to fire the fuel mixture.
Old Dec 12, 2018 | 05:58 PM
91calijag's Avatar
Problem solved...
New cap and rotor solved the problem. The terminals inside the cap appeared to be eaten away just a little, probably just enough to increase the clearance between the end of the rotor and the cap terminals.
MilitaryMan33
Aug 15, 2014 07:24 PM
BlackMac
Jul 3, 2014 04:16 AM
WinterJag
May 18, 2012 12:38 PM
SeldomJAG
Oct 11, 2011 12:21 PM
Jpetreeko
May 20, 2011 07:14 AM
