XJ40 ( XJ81 ) 1986 - 1994
Power steering 88 vanden plas xj6
Old Feb 13, 2025 | 08:00 PM
Eully's Avatar
Default Power steering 88 vanden plas xj6
Castor hydraulic system mineral oil is no longer available. I know I will have to DIY the dispensing tube. Wondering if Valvoline LHM Plus Hydraulic Oil, will work as an alternative. If not what will? TIA
Old Feb 16, 2025 | 05:37 PM
motorcarman's Avatar
The 1988/89 XJ40 should be fitted with a separate ATF reservoir for the PAS fluid.
The HSMO is for the SLS and power assisted brake system.
1990-1992 used HSMO for BOTH SLS and PAS.
1993/94 should revert back to ATF for the PAS.
Old Feb 24, 2025 | 10:33 AM
xjack's Avatar
As far as i understand atf and hsmo are of very close specification and probably can be used interchangeably, but for peace of mind use lhm+, it is fine, i've been using it for years without any problems
Marty Malone
Dec 7, 2022 04:22 PM
Giojim98
Feb 15, 2022 08:03 PM
w1n9m4n
Apr 23, 2015 10:19 AM
Trueblood
Mar 10, 2014 10:54 AM
id1207
Nov 26, 2011 09:12 PM
