XJ40 ( XJ81 ) 1986 - 1994
recognizing aj6 4.0l engines
Old Nov 4, 2009 | 07:01 AM
dimsum29's Avatar
Default 4.0 xj6
valve cover says 4.0
engine/ transmission for sale 4.0 xj6
dimsum29@hotmail
Old Nov 5, 2009 | 04:07 PM
db in uk's Avatar
Originally Posted by Dutchjaguar
Hi,
For my next project I'd like to use the aj6 4.0l engine from a xj40.
How can I tell that the block I'm looking at when at a breakers yard is actualy a 4.0l and not a 3.6l and 3.2l ?
Are there any significant differences on the outside of the engine (apart from the 4.0 badge, which can easily be replaced)?
If anyone could help me, I'd really appreciate it
greets,
Ben
The Netherlands
The exact engine version is identifiable through the engine number.
The second character of the engine number gives its displacement. If I remember right,
A=2.9 (sohc),
B=3.2,
C=6.0 V12,
D=3.6,
E=4.0
As a quick guide if the engine is still in the car, the 3.2 and 3.6 engines use a transmission cable attached to the throttle coupling on top of the throttle body, whilst the 4.0 transmission uses electronics so has no cable there.
This site includes an engine number decoder, though you will need access to the internet in the breakers yard to input the numbers!!
http://www.jaguarsport-xjr.com/html/engine.html
Hope this helps,
David
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
OkieTim
Sep 2, 2015 12:48 PM
