XJ40 ( XJ81 ) 1986 - 1994
Speaker Replacement Plug and Play Suggestions
Old Jul 6, 2018 | 07:41 AM
supra-raleigh's Avatar
Default Speaker Replacement Plug and Play Suggestions
On a 93 XJ6, the 4 door speakers need replacement. I am looking for some good aftermarket options which are direct plug and play.
Can someone please provide some suggestions? Thanks
Old Jul 6, 2018 | 09:42 PM
al_roethlisberger's Avatar
If you want true "plug and play" compatibility, believe it or not the OEM speakers are still available:
https://www.jaguarclassicparts.com/u...rs/loudspeaker
DBC6220
LNA4140BA
But they aren't inexpensive. If someone has an aftermarket replacement that is a good match in impedance, power efficiency, power rating and mounting to the original, that would be good to know.
Old Jul 15, 2018 | 08:28 PM
dtrain's Avatar
Default aftermarket speakers
I replaced the speakers in my '92 a few years ago. These aren't the exact speakers that I have but I purchased a similar version and have not had any problems:
https://www.bestbuy.com/site/pioneer...?skuId=6065206
You have to remove the factory connector and the screw holes aren't perfectly aligned but it took about 10 minutes to install each one once the door panel was removed.
car5car
Feb 15, 2016 07:03 AM
cyber3d
Jan 18, 2016 04:02 PM
Elbert Jones
Dec 29, 2012 07:41 PM
Thundercat
Nov 16, 2011 05:24 PM
androulakis
Jan 22, 2011 12:56 PM
