XJ40 ( XJ81 ) 1986 - 1994
Steering rack MOT fail
Old Nov 8, 2021 | 09:51 AM
darylSeven's Avatar
Default Steering rack MOT fail
I have a 1991 XJ40 3.2 and it failed its MOT with:
"Steering rack insecure to the extent there is excessive movement at the mountings"
After ordering what I thought would be the correct steering rack moun
ting bush kit from ebay, I have discovered that there is more than one type of steering rack for the XJ40. My mechanic, Scot, has given me a picture of the part needed. In the picture the part is at the bottom and looks a bit like a fishing reel.
Does anyone here know where I might find 2 of these? Or do I need the whole steering rack? I spoke to SNG Barratt and they can recondition them for about £750, but that's not really an option for me.
Thanks!
Daryl
Old Nov 9, 2021 | 05:52 AM
jerry_hoback's Avatar
I see you've had a mechanic look at it. Ok, good. But if I read the problem description correctly, doesn't that just mean the rack assembly is loose on the car at its mount bolts? Just throwing it out there.
Some years back I replaced mine for an aggressive leak. I was able to find a rebuilt one on eBay for about $250 (at the time of course). Good luck!
Old Nov 9, 2021 | 10:17 AM
darylSeven's Avatar
Thanks Jerry, that's a good point, it could just need tightening up. In my conversation with the MOT garage though, he said I needed new bushes as it, the steering rack, was sliding left to right. I'm having the work done at a different garage, so when I get it back down there I will put that to him.
In the meantime, I have found the right bushes for the steering rack mounts here:
https://www.britishparts.co.uk/class...ount-kit-p1359
And after speaking to them, they told me there was only ever one type of steering rack ever fitted to the XJ40. So I'm confused about what I had ordered before...
Old Nov 9, 2021 | 11:00 AM
As I recall it was 2 companies making essentially the same unit but I am not sure. I definitely recall a wide range of prices even on new not rebuilt ones. If you do need to rebuild yours I would suggest replacing it due to the relative ease of the job. 4 bolts, 2 tie rods, 2 hoses. And you'll probably want an alignment either way.
Old Nov 9, 2021 | 11:31 AM
Lawrence's Avatar
There are two racks fitted, the 1991 car uses the Adwest brand rack, late cars the ZF brand.
AFAIK they are not interchangeable without at minimum a steering column modification.
Larry
Old Nov 9, 2021 | 04:28 PM
Maybe that's why I don't remember. It didn't affect me. ?
Old Nov 12, 2021 | 09:17 AM
darylSeven's Avatar
Thanks Lawrence
I'm guessing that's when Ford took over. Am I right in thinking that they then used the ZF rack in the XJ40 replacement, the X300?
Old Nov 12, 2021 | 11:56 AM
Lawrence's Avatar
Originally Posted by darylSeven
Thanks Lawrence
Could be ..all I know is that my 94 has a ZF rack in it
Larry
05strSATX
XJ40 ( XJ81 )
Jul 21, 2021 09:10 PM
Doug
Feb 4, 2021 07:40 AM
yachtmanbuttson
Aug 10, 2018 08:11 PM
rik881
Mar 1, 2017 05:17 PM
Rique
Oct 2, 2009 03:19 PM
