XJ40 ( XJ81 ) 1986 - 1994
Steering Stiff on Start
Old May 22, 2015 | 01:01 AM
Gardianlh's Avatar
Default Steering Stiff on Start
Ok, so I could be incredibly stupid and just be low on steering fluid in my 89 XJ6, but every time I start the car, the steering column is so stuff that I can't move the wheel hardly at all. I have to wrestle with the steering wheel until I feel it "snap" and loosen up. Warming up the vehicle makes no difference, and it is worse in cold weather, however it does happen in hot weather. Any suggestions?
Old May 22, 2015 | 09:20 AM
Don B's Avatar
Hi Gardianlh,
You do need to check the power steering fluid level. The Haynes manual shows how. The reservoir is under the hood near the right wheel well. A common indication of low fluid is a "groaning" noise from the steering system. If you find the fluid is low, check for leaking fluid under the reservoir and at the pump (to find the pump, follow the large diameter hose from the reservoir down toward the lower front of the engine). The most common fluid leak point is the low-pressure hose from the reservoir to the pump. The photos at the link below show our '93, which is a little different from your '89, but the principle is the same:
Welcome to Jag-lovers - Members Photo Viewing Page
Check the tension of the main drive belt that powers the alternator, water pump and power steering pump. If it's loose, you may not be getting full power assist.
Some owners have needed to rebuild their power steering pumps - I don't know if the rebuild kits are still available, but hopefully this won't be your issue.
Cheers,
Don
Old May 22, 2015 | 07:24 PM
motorcarman's Avatar
I think there was a TSB about this fault about 20 something years ago but I don't remember the details. I looked through my TSBs in .pdf but it might be in a paper form that never got put into a digital format. (not all Jaguar TSBs were)
There are HUNDREDS of TSBs from the early 'paper days' that are not digitized and are kinda lost to obscurity.
It sounds like the valves in the steering rack are 'sticky' and you might try to flush the PAS system. An additive for Auto gearboxes that has a slight solvent might help if the valves are 'gummed-up'??
You could try the additive and if it helped, then flush the system with new fluid.
I think the solution 'back-in-the-day' was to replace the steering rack assy.
Try more research??
bob gauff
Old Jul 4, 2017 | 03:58 AM
vinss's Avatar
Hi!
Did you figure out what was the problem? I have exatcly the same problem, and my bet is on pump. But at the same time I have just rebuilt my stearing gear and it might be the problem too.
Old Jul 4, 2017 | 10:01 AM
JgaXkr's Avatar
The issue with the steering being stiff when first starting your car is the pinion seal. When those cars were new we were changing the steering racks for this issue.
Old Jul 4, 2017 | 10:51 AM
vinss's Avatar
I just rebuilt the rack and I was hoping that problem is in different place, but most likely and logically it is rack. Are Adwest easy interchangeble with ZF? I have zf on other xj40 that is going to garbage.
Old Mar 2, 2018 | 08:05 PM
Paul Thompson's Avatar
Default Mine does this ..
all i do when i first start from cold . If it feels stiff i give it a little rev . Switch the car off then start again with a little bit of a rev and its working fine .. first time everytime ...
rusty37
Apr 5, 2020 07:40 PM
PMKimpton
Aug 3, 2019 08:22 PM
sogood
Sep 15, 2015 07:35 AM
AL NZ
Sep 4, 2015 08:39 PM
dcvickers
Sep 2, 2015 06:14 PM
