XJ40 ( XJ81 ) 1986 - 1994
Subframe Broken - RESOLVED
Old Jun 17, 2023 | 05:09 AM
HerbieOPF's Avatar
Default Subframe Broken - RESOLVED
Hello!
The front subframe on my XJ40 4.0L is badly rusted and broke. I'm now looking for a replacement.
I have found these parts on eBay and an Austrian eBay-esque site but I'm not sure if it will fit since it's from a 3.2.
Any advice would be appreciated.
Jan
https://www.willhaben.at/iad/kaufen-...hse-682694754/
https://www.ebay.at/itm/Jaguar-XJ-Vo...-127634-2357-0
Last edited by GGG; Jul 31, 2023 at 03:06 AM. Reason: Add "RESOLVED" to thread title
Old Jun 17, 2023 | 10:03 AM
Roger95's Avatar
Genuine & Authentic Classic Parts | Jaguar Land Rover Classic Parts Should confirm your choice this is an invaluable source for parts information.
Roger
Old Jun 17, 2023 | 02:42 PM
Scd's Avatar
Scd
Hi, the key here is when Jaguar widened the front chassis legs so the new subframe would accept the v12. If your battery is in the boot your need the later version, and vice versa. As per the previous post from Roger 95 have a look at the part numbers.
Old Jun 19, 2023 | 04:10 PM
HerbieOPF's Avatar
Thank you very much.
​​​​​​Seems like the V12 version also has major visual differences judging by the Jaguar site. So I'm pretty sure the parts listed on eBay will fit.
Old Jun 20, 2023 | 12:24 AM
Scd's Avatar
Scd
Hi, my apologies but I perhaps did not explain this correctly. The later ( battery in boot) cars had wider front chassis legs to accept the V12 subframe and at the same time a revised 6 cylinder subframe was introduced. The v12 and 6 cylinder parts are not interchangeable, and a later 6 cylinder subframe will not fit a pre1993 (battery under bonnet) car and vica versa. Hope this makes things a bit clearer!
Old Jul 27, 2023 | 05:22 PM
HerbieOPF's Avatar
Thank you!
Ordered a new subframe, installed it. Everythings perfect again!
Sportston
35
Apr 9, 2023 07:34 AM
Marley
E type ( XK-E )
Jun 24, 2021 08:17 PM
MWMan
Jan 23, 2017 03:20 AM
Bleujag
Aug 3, 2015 08:11 PM
