XJ40 ( XJ81 ) 1986 - 1994
Talking alternator !
Old Jul 6, 2012 | 11:10 AM
jeffH's Avatar
Default Talking alternator !
My beloved '94 XJ40's alternator is making a lot of mechanical noise on start-up. It makes the sort of noises that lead me to believe that the stator is loose on the shaft. When you rev the engine up to about 1500 rpm, it makes a short shriek, and then is perfectly fine until you shut it down again and another start from cold.
The belt is A-OK, tensioned properly, and the pulley isn't loose, runs fine and true.
Anybody ever ran into this? Thanks !
Best -
Jeff
Old Jul 6, 2012 | 11:21 AM
Mikey's Avatar
Sounds like a dry bearing to me, I had something similar on my old Corvette.
Old Jul 6, 2012 | 01:53 PM
jeffH's Avatar
Default Right on -
Mikey, you were right "on the money". It is indeed a dry rear bearing.
Many thanks -
Jeff
10 XF Premium
Oct 2, 2015 09:22 PM
waynepaulj
Oct 2, 2015 04:05 PM
CaptainHam
Oct 1, 2015 02:01 AM
MattB731
Sep 30, 2015 10:37 AM
