XJ40 ( XJ81 ) 1986 - 1994
Thermostat Location for Heated Seats?
Old Dec 16, 2010 | 10:24 AM
Bulldoggin's Avatar
Default Thermostat Location for Heated Seats?
Does anyone know where the themostat for the heated Drivers side seat is located?. Wiring diagram says in the seat cushion but I can not find anything that resembles a heater stat?
Mike
Old Dec 16, 2010 | 12:36 PM
Brutal's Avatar
It should be part of the heater pad and electrical grid, in otherwords you need a new heat pad
Old Dec 16, 2010 | 03:53 PM
Bulldoggin's Avatar
Well I took the plunge and removed the front edge upholstery cllips and reached in under the cover and found it about half way back towards the right side. It is under some burlap like cloth and was much smaller than I expected. Cut the cloth close to the stat, a little larger than the largest button battery available. As soon as I touched it one of the wires fell off.
That is/was the problem.
So it is in there on the seat bottom cushiion. Happy that's over with.
Doug
Feb 27, 2019 01:31 AM
GordoCatCar
Jan 2, 2017 01:10 PM
adam699
Sep 12, 2015 05:32 PM
Clamdigger
Sep 12, 2015 03:43 PM
Quebecjag
Sep 10, 2015 06:06 AM
