XJ40 ( XJ81 ) 1986 - 1994
Thump on braking 94 XJ12
Old Apr 20, 2023 | 07:10 PM
alabbasi's Avatar
Default Thump on braking 94 XJ12
So I get a loud thump on braking at times when I apply the brakes hard. Shocks or bushings?
Old Apr 20, 2023 | 07:52 PM
944play's Avatar
My '95 needed a transmission mount bushing. Symptom was a heavy metallic thunk during ABS-inducing stops.
Old Apr 20, 2023 | 08:17 PM
alabbasi's Avatar
Thanks, this one seems like it's coming from the front.
Old Apr 24, 2023 | 05:14 PM
jerry_hoback's Avatar
If it only happens on braking , then it's not likely the shocks although those bushings are a known "weak point" Maybe pull the front wheels and have a good wiggle on the calipers? Perhaps they are sticking on the slides?
Old Apr 24, 2023 | 05:15 PM
alabbasi's Avatar
Jerry, thanks. I'm being super lazy as my lift is tied up but I'll try to get the wheels off this week. I was wondering if it was a control arm moving or something along that line. It happens on hard backing and does make quite a bang, as if something shifted
Old Apr 26, 2023 | 08:30 AM
Don B's Avatar
Hi alabassi,
There are many possible suspects for your thump: control arm bushings, ball joints, subframe Vee mounts and rear pivot bushings, wheel bearings, shock bushings, brake caliper guide pins and bracket mounting bolts, transmission mount (that noise usually comes from under your seat), rusted body mounting points, etc. It could be a serious safety issue, so you're going to have to take a good look at everything.
Cheers,
Don
mtotrainer
XJ XJ12 ( X305 )
May 17, 2022 06:10 PM
SteveJacks
Jan 11, 2015 11:42 AM
marshgrp
Aug 1, 2011 03:42 AM
catwithahat
Dec 5, 2009 05:28 AM
JSJAG
Oct 9, 2009 03:13 PM
