XJ40 ( XJ81 ) 1986 - 1994
warning indicator light
Old Jan 13, 2009 | 12:01 PM
Frankie's Avatar
Default RE: warning indicator light
I have an '88 XJ6 and the light you might be refering to is the warning light for low mineral oil in the brake system. The brake system power assist is under pressure with fluid not vacuum
" Green Jag Juice" is available at any foriegn auto parts store and runs about $10 for a small container( @ pint or 2).
Old Jan 14, 2009 | 12:44 AM
Geofux's Avatar
If you're low on brake fluid it would probably also mean that you are also leaking brake fluid...
Old Jan 14, 2009 | 12:52 AM
JagtechOhio's Avatar
Rayray, click on my screen name and send me a PM if you want a set of owners handbooks for your car. Frankie is exactly right, and you need mineral oil before you lose brake assist. You're not gonna be happy when you have to fix the leak, but that's another question for another day.
Geo, there is a different warning he would be seeing for "low brake fluid" if that were the case.
99xk8guy
May 28, 2024 09:36 PM
D.K
Dec 10, 2023 02:05 AM
Jpav27
Jul 31, 2022 06:43 AM
mrplow58
Sep 9, 2015 11:27 AM
Mosers63
Sep 6, 2015 02:53 PM
