XJ40 ( XJ81 ) 1986 - 1994
What is this rotary dial on the back of the seat adjustment switch (MY94)
Old May 11, 2023 | 12:27 AM
JensenHealey's Avatar
Default What is this rotary dial on the back of the seat adjustment switch (MY94)
I just ordered a replacement seat control switch for the passenger side front seat on my newly acquired 1994 XJ12 (XJ81) and in looking at the old one and the pictures of the replacement switch in several ebay listings I see a rotary dial on the back of the switch. The part number for this switch is DBC11320. The driver's side switch is DBC11321. See photos below:
Front of switch
Back of switch
What is this green rotary dial on the back of the switch?
Old May 11, 2023 | 02:10 AM
944play's Avatar
I'd bet it's a backlight bulb (12V, 2W), not a dial. Give it a quarter turn counterclockwise and see if it comes out.
Old May 11, 2023 | 02:46 AM
Default Not a dial, but instead a bulb access hole
Yes, you are correct. This is an access method to replace a miniature bulb inside the switch.
Old May 20, 2023 | 08:20 PM
alabbasi's Avatar
Speed control, if you turn the dial all the way clockwise, it will launch the occupant out of the sunroof. Be careful as there's one on each seat control. Depending on RHD or LHD, it should be set for the passenger for obvious reasons.
Superstox
Aug 3, 2022 12:01 PM
v1rok
Oct 13, 2019 05:23 PM
darbysan
Oct 1, 2019 09:48 AM
jahummer
Mar 2, 2014 01:31 PM
berlin1977
Dec 7, 2012 02:49 PM
