XJ40 ( XJ81 ) 1986 - 1994
Wheel Bearing Replacement
Old Mar 26, 2014 | 01:28 AM
cm410638's Avatar
Default Wheel Bearing Replacement
Afternoon,
I've been told that all four of my wheel bearing's need replacing. I have a friend whom is a mechanic and he was the one who diagnosed the issue for me and I have now taken it to a Jaguar mechanic to be fixed.
I was just wondering what you guys think would be the average cost on my 1990 XJ40?
Would be helpful to have a ball park figure so I'm not having games played with me.
Thanks guys.
Logan
Old Mar 26, 2014 | 01:38 AM
Cambo's Avatar
Welcome to the forum Logan.
I can't tell you how much it'll be, but i'm sure someone who knows will be along shortly.
You should stop by our new members area New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum and introduce yourself.
And have a look at the XJ40 section too XJ40 - Jaguar Forums - Jaguar Enthusiasts Forum
Old Mar 26, 2014 | 01:59 AM
Mmmmm, all 4 wheel bearings, rather bizarre, even for a '40.
Front wheel bearings are same as Falcon, rears are Jag specific.
I see wheel bearing kits on "AU Ebay" regularly for about $40/wheel.
Labour is generally $100/hour, and I reckon the fronts would be 4 hours, and the rears, NO idea, never done them on the outboard brake cars, but the inboard versions are very time consuming, coz all the bits that need removing are HEAVY.
I had similar noises with the X300, and after days of diagnosis, turned out to be tyres, recently fitted Simex?, bugga. New set of boots from Bridgestone, silent as.
I had suspected them all along, and a set of wheels from another Jag fitted as a test run, sealed the decision in a heart beat.
Old Mar 26, 2014 | 07:19 AM
Good advice there from Cambo and Grant as always....
I find it rather strange that all 4 wheel bearings have gone too??
Old Mar 26, 2014 | 07:45 AM
Doug's Avatar
I don't find it all that odd that bearings need replacing at all four corners. There's no mention of all four going bad *at the same time*. That would be a very strange thing, I agree.
The fronts can last virtually forever if they're cleaned and repacked with fresh grease every 30k miles or so. But this is often neglected. I've had to replace both sides on various cars over the years.
An owner can do nothing but hope on the rears, though, as there's no practical way to treat them to any periodic TLC. Fortunately the bearings are generously sized so they'll often soldier on long past the time when they should've been replaced. I've worked on several Jags with bad rear bearings, both sides, and the owner had no idea.
BrentGardner
29
Dec 16, 2024 12:13 AM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
JaguarXKR
Sep 6, 2015 11:47 AM
Bcrary3
Sep 3, 2015 10:54 AM
TC Johnson
Aug 29, 2015 08:55 PM
