XJ40 ( XJ81 ) 1986 - 1994
Where is DBC6916 left hand splice box?
Old Nov 11, 2019 | 01:58 PM
JensenHealey's Avatar
Default Where is DBC6916 left hand splice box?
While trying to figure out my fan wiring difficulties I found the following part on ebay
DBC 6916 left hand splice box
Where is this located? I am just wondering if the two wires I am attempting to follow are somehow joined inside this "splice box"
Old Nov 11, 2019 | 02:25 PM
Lawrence's Avatar
I don't recognize that part. Do we have that on N American models? Or is that the back of the fuse box?
I think that's what it is - part of the fusebox assembly that the harnesses plug into.
Old Nov 11, 2019 | 03:55 PM
Default Back of fuse box
No, this is the back of the fuse box at the bottom of the driver's A pillar.
back side of LMD2827AA fuse box
This is the back side of this splice box which you will see specifically says XJ40 5/93
back side of dbc6916 splice box
Old Nov 11, 2019 | 04:05 PM
Lawrence's Avatar
Yeah I saw the part number and the notation on the sticker but searching the part number on the Jag heritage site come up "no such part" so not sure?
Oh and you have to undo that big bolt to get to the circuit boards in the fusebox.
Old Nov 13, 2019 | 12:56 PM
Don B's Avatar
I can't find the part numer at jaguarmerriamparts.com, either. From the size of the pins, it probably is not suitable for battery power distribution, but it could be related to ignition-switched power or ignition-switched grounds. If your car has a splice box like that, there are probably only a few places it would be mounted:
Behind one of the knee bolsters/underscuttles or near a corner of the dash, perhaps mounted on the climate control blower motor housing
In the center console
Somewhere in the trunk behind a carpeted trim panel
Can't wait to see if you find it somewhere!
Cheers,
Don
JagQ
Aug 29, 2019 11:33 AM
jakesdad
Apr 24, 2018 02:39 PM
Christian Pugh
Jan 7, 2017 05:27 AM
zjhette
Jul 8, 2013 03:29 AM
JameyXJ6
Apr 1, 2012 03:48 AM
