XJ40 ( XJ81 ) 1986 - 1994
XJ40 Headlight
Old Jan 31, 2012 | 05:15 PM
Tim Webb's Avatar
Default XJ40 Headlight
Hi,
Could anyone tell me if a 90-94 model XJ rectangular headlight fit a 87 model XJ40?
Regards Tim
Old Jan 31, 2012 | 07:43 PM
limegreenclown's Avatar
Im pretty sure they will you just have to change the bulb fail modules or lamp control modules.not positive though.
Old Jan 31, 2012 | 10:13 PM
malibudav's Avatar
Hey there Tim,
The XJ40 began in 1988. If you have the rectangular headlight assembly, it probably has to do with the fact that you are in Sydney (not sure!). The rectangular headlight assembly is by far a better quality set up than the rounds, although most favor the look of the rounds. I personally think the rounds on the XJ40's look like an afterthought as opposed to the older, and then later Jags that are "molded" into the body.
My beautiful 1994 has rectangular lamps and I love the look and the functionality (much better than the rounds).
Find a wrecker as the dealer will charge you a King's ransom.
Good luck.
Old Feb 1, 2012 | 05:20 AM
Cadillac's Avatar
Superb , finally I have seen someone that actually likes rectangular lights as I do lol
Old Feb 1, 2012 | 06:29 AM
mrtalkradio's Avatar
I'm a fan of them as well.
Old Feb 1, 2012 | 04:00 PM
MidwestJag's Avatar
Didn't the XJ40 begin production in '87 outside of the States, and even late '86 in some areas?
Opinion... My car has the round lights, which I like very much. But, if it had the squares, I don't think I would like them less. I think the square lights are very handsome and fit neatly into the distinctive angularity of this era Jaguar.
Cheers!
Scott
Old Feb 1, 2012 | 07:24 PM
Tim Webb's Avatar
Hi Limegreen,
Thanks for your reply, much appreciated.
Kind Regards
Tim
Old Feb 2, 2012 | 08:29 PM
Tim Webb's Avatar
Default Good Taste
You obviously have fine taste to, keep up the good work Buddy!
Old Feb 2, 2012 | 09:19 PM
Jeh's Avatar
Jeh
Thats why I bought mine. I love the front end on the late XJ 40s.
Old Feb 2, 2012 | 11:16 PM
malibudav's Avatar
Wow. What a beauty!
Old Feb 3, 2012 | 03:58 AM
Cadillac's Avatar
You have a gorgeous ride
Thanks Tim
Old Feb 3, 2012 | 07:14 AM
Jeh's Avatar
Jeh
Sorry, but I can't claim that car. I just wanted to show an awesome front end and that was a sweet pic.
Old Feb 3, 2012 | 01:56 PM
db in uk's Avatar
Me too!
Old Feb 3, 2012 | 02:03 PM
db in uk's Avatar
Originally Posted by Tim Webb
Hi,
Regards Tim
The rectangular 'Fishtank' headlights are interchangeable with the twin round ones on any model year. The fittings are the same and the headlight units just bolt on to the front of the car.
Limegreenclown is correct that you will need the correct bulb failure modules - one for each side. These fall into three types:
1986-89
(to VIN524374) - DBC3180
This is the early module which can suffer problems from dry solder joints. Luckily the later modules (not 93/94) are all interchangable.
1990-92
(from VIN52437 to VIN643649) - DBC3266
(from VIN643650 to VIN667828) - DBC5240
These two modules will also fit your car and will be very reliable units.
Lastly, units from VIN667829 - 1993 and 1994 model year modules will NOT fit your car since the plugs on the loom end are incompatible. However the 93/34 headlight units themselves will fit.
These part numbers are for non-UK, non US market cars.
UK bulb failure modules will work with your car but have a dim-dip function on which the headlights glow dimly when the side lights (small lights in bumper) are running.
USA bulb failure modules are different and incompatible since they incorperate running lights in the bumper's sides - and the rectangular headlights have two bulbs in them.
Old Feb 3, 2012 | 02:22 PM
db in uk's Avatar
Thats a very rare version of the XJ40 - the Sovereign Gold. Only about 200? of them made and a sky high spec.
Old Feb 3, 2012 | 04:31 PM
NEO Cat's Avatar
Default Rectangular headlight
It looks like the non US cars have a slightly smaller rectangular headlight than the US cars. Note the larger gap between the grill and the edge of the headlight. I think I like that style a bit better than the US version.
Old Feb 6, 2012 | 03:52 AM
Tim Webb's Avatar
Hi,
Thanks for your post, very helpful. You really know your Jags.
Regards Tim
hoodun
Nov 20, 2022 02:35 PM
kingdom worker
Nov 14, 2020 03:47 PM
Fletch44
Sep 28, 2015 02:21 PM
kevinl
Sep 24, 2015 08:25 PM
