1987 s3 xj6 engine turnover but no start issue
Old Jul 30, 2023 | 08:28 PM
retroren's Avatar
Default 1987 s3 xj6 engine turnover but no start issue
Need some advice. When I turn the ignition key to start, the engine turns over but will not start. I measured 34psi at the fuel rail so I am ruling out a fuel issue. I just put a noid light on each injector and cranked.. I viewed a dim flicker of the noid light as I cranked for each injector. The cold start injector and extra air valve (injector?) each stayed lit solid while I cranked the engine. What would be a next step? Thanks Ren
Old Jul 30, 2023 | 09:11 PM
Doug's Avatar
Check for spark
Old Jul 30, 2023 | 09:36 PM
Bill Mac's Avatar
By the way when checking for spark (as Doug says) pay particular attention to the distributor rotor arm.
I have seen this fail internally and short to earth on a few occasions.
Old Jul 31, 2023 | 06:43 PM
retroren's Avatar
I purchased an inline spark tester and tested each plug. The tester flashed for the plug that was being tested so I conclude I have spark. I should seeing I have a new coil, plugs, ignition wires, distributor cap, pickup coil and ignition amplifier. As previously mentioned, the fuel gauge I installed showed 34 psi at the fuel rail while cranking so I also conclude I have fuel . I should as I replaced the fuel pump and fuel filter. I should note the car performed really well the last time I got it started. Quite well in fact.
Okay, in my original post, I mentioned the Noid light test showed a brief, really weak glimmer of the filament as I tested each injector pulse. What's my next test/thing to test?
Old Jul 31, 2023 | 07:39 PM
retroren's Avatar
Also meant to ask, does the 87 xj6 have a crank position sensor? If so where is it located?
Old Jul 31, 2023 | 07:43 PM
retroren's Avatar
Should have read more before I asked. The cps is Integrated into the distributor assembly.
Old Jul 31, 2023 | 09:26 PM
sov211's Avatar
And the ignition module at the front of the block, right hand side? If this fails, and they do fail (less often on the 6 cylinder than on the V12). The failure point is the GM Delco module inside, D1906.
Old Jul 31, 2023 | 10:38 PM
retroren's Avatar
Installed a brand new ignition module/amplifier with no change in symptoms.
Thatch
Jan 7, 2023 11:49 AM
pyro
Jan 5, 2020 06:47 PM
Desiderata
Feb 23, 2016 08:56 PM
ahunt4
Jan 24, 2015 05:45 PM
jagon
XJ40 ( XJ81 )
Jan 15, 2008 01:26 AM
