1987 xj6 jag no fuel to motor
Old 01-01-2010, 05:11 AM
m0t0rm0uth's Avatar
#1 cylinder being at the rear, the firing order is:
1 - 5 - 3 - 6 - 2 - 4
To find the position of #1 wire, put #1 cylinder at TDC (top dead center) by taking out the plug, and shining a flashlight into the plug hole. Crank the engine until the piston is at TDC. Then take off the distributor cap, note the position of the rotor, and that is where the #1 wire goes.
Determine rotating direction by seeing which way the rotor turns when rotating the engine with the cap off.
Old 01-03-2010, 11:46 AM
Received 1,231 Likes on 716 Posts
Clockwise.
But Wishpony, what has any of this to do with the title of the post 'No Fuel to Motor'??
toronadomike
08-07-2022 03:41 PM
Sprayall
05-30-2021 08:13 AM
allenman85
05-10-2021 03:11 PM
alpecsa
09-07-2015 11:55 AM
Sprayall
09-03-2015 07:49 PM
Quick Reply: 1987 xj6 jag no fuel to motor
