'84 XJ6 Thermoswitch Question
Old Aug 2, 2011 | 01:10 PM
Benhamtroll's Avatar
Default '84 XJ6 Thermoswitch Question
In my ongoing work on my problems with leaking and overheating, I discovered today that the thermoswitch for the electric fan was disconnected. Since the repair manual I have says "make a note of the location of the electrical leads," I'm a little stumped on how to hook them up. I would just try it both ways, but I'm not even certain if the switch is still good!
Anyone know which one goes where, or at least have a pic of how theirs is hooked up?
Thanks!
Old Aug 2, 2011 | 02:06 PM
Doug's Avatar
It's just an on-off switch. Doesn't matter which way the wires are connected.
Does the e-fan work of you touch the two wires together?
Old Aug 2, 2011 | 02:29 PM
It does not. It may be a fuse, but I can't seem to find a fuse diagram for the under-bonnet box.
Old Aug 2, 2011 | 03:37 PM
Doug's Avatar
It's the #1 fuse (forward most) in the underhood fuse box.
Old Aug 2, 2011 | 03:41 PM
Thanks! I'll check it.
Old Aug 2, 2011 | 04:29 PM
Okay. I checked through, and have determined that I have power to the relay. When I connect the two leads, I can hear the relay click, but the fan does not turn on.
At this point I'm assuming I had a bad fan motor . . .
Old Aug 2, 2011 | 06:25 PM
hlgeorge's Avatar
Check the voltage at the fan motor to be sure the relay isn't defective.
Old Aug 2, 2011 | 07:56 PM
Doug's Avatar
Could be.
Here's some reading
Aux Electric Cooling Fan Checklist, Series III
Old Aug 3, 2011 | 10:44 AM
Okay. For some strange reason the fan came on this morning while I was driving around. So now I have to conclude I have a loose connection somewhere. Joy.
rusty37
Apr 5, 2020 07:40 PM
pnwrs2000
Jan 15, 2018 07:20 PM
carcycle
Sep 7, 2015 04:14 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
