85 XJ6 Engine Start Problem
Old Aug 27, 2020 | 05:10 PM
mikega's Avatar
Default 85 XJ6 Engine Start Problem
i know the solution is here from the expert/
My 85 XJ6 Series 3 of late starts from any gear, P, R, N, D, 1, 2.
I this normal?
if not normal, what could be the issued and how to resolve it?
Mike
Old Aug 27, 2020 | 05:51 PM
Jose's Avatar
it should only start in P or N.
so it could be the Neutral Safety Switch, which in the 1985 can be located on the side of the transmission under the car, or in front of the shifter tower depending when the car was built.
at the transmission it will be a round switch with 4 wires connecting to it.
at the shifter tower it will be a roller switch with 3 wires.
Old Aug 27, 2020 | 08:23 PM
Doug's Avatar
Another thought:
If the neutral switch might have been bypassed. An easy way is simply simply ground the black (or black/green) wire at the starter relay, but there are other possibilities. This would typically been done if the neutral safety switch was giving problems. So, if you find a problem with the switch you might still have to look for altered wiring that would suggest it was bypassed.
Old Aug 27, 2020 | 10:26 PM
LT1 jaguar's Avatar
Active Streak: 60 Days
Just a note: My 1985 S3 has serial # 417xxx and the neut/safety switch was on the transmission and it is the green/black wire that goes to the starter relay.
Wascator
Sep 11, 2019 11:37 AM
Madjagden
Aug 16, 2016 06:01 PM
bob peers
Feb 27, 2016 08:20 AM
Efrain Arizpe
Feb 24, 2009 12:08 AM
cward
Jul 10, 2008 08:06 PM
