'85 XJ6 Transmission Issue - Hard to shift, no forward movement.
Guest
Posts: n/a
Got a 1985 Jaguar XJ6. Got a new automatic transmission put in as the old one was just shot. Paid someone to get that popped out and the new one put in, but beyond the actual act of physically removing one and throwing a new one in, I just don't think the guy knew exactly what he was doing, so it's out of there and I'm about to see what I can do myself. Which I didn't really want to do as it'll probably take me twice as long to do, but as is I'm looking for a bit of help. If I know what to do or try, I can get around to it in my free time and hopefully having it back up and running.
As is right now, the car will move in reverse, but not forwards. And the actual act of shifting the gear selector is fairly difficult. (The old transmission, prior to it going, the act of shifting the gear selector was nice and smooth like one would normally expect of a car.)
Now, prior to this, the mechanic that did put the transmission in had told me the car was going forward, but that it was up-shifting fairly rough. Then, next I was told it wasn't shifting out of first gear, then finally that it wasn't going into any gear at all. Apparently this all happened in a fairly short amount of time.
Now, like I said. As far as my knowledge of automatic transmissions goes, it doesn't go far. Never had to work on one, so never got around to learning about them. However, if I can be pointed towards what could be an issue and ways to resolve it or pinpoint and troubleshoot the problem(s), I'm mechanically inclined enough to get something done.
Anyway, thanks to anyone who can give me some ideas or advice.
Greetings,
I am NOT an automatic transmission rebuilder. I have changed dozens of faulty transmissions on Series III XJ6, so here is what I can contribute after reading your post:
The external controls for this transmission are simple. Nothing ever goes wrong with the selector itself that will cause difficult movement or engagement. The condition of the gear selector cable, and its adjustment, can be a big deal.
Try disconnecting the gear selector cable at the transmission end, and see if the shifter is hard to move. It's possible that the cable was damaged at some point during the attempted repairs, since it wasn't stiff before.
If you can run the car with the rear wheels off the ground safely, you could also try this: with the cable still disconected at the transmission, move the selector lever on the transmission by hand into the neutral position. Start the engine, and manually shift it into drive from under the car. Do you have any forward gearing?
You can do this with the car on the ground if you want, by removing the transmission tunnel left side carpet and removing the access cover for the transmission end of the cable. Then you can reach from inside the car and shift the lever on the side of the transmission by hand: that's how I drive a car into my shop so I can raise it up and replace a broken gear selector cable.
There is an external adjuster for both the front and rear bands on this transmission. If you have no forward gearing, you have alot more than a minor band adjustment problem, unless someone has backed out the front band adjuster ALOT.
The kickdown cable adjustment on BW model 66 transmissions is the method used for setting the required pressures. You need a pressure gauge and the specific sequence to set pressure at stall speed: the shift points will be wacked out if this adjustment is not close. It will still have forward gearing, at least for a while, if the pressures are radically incorrect.
In the end, it sounds to me like the transmission installed in the car wasn't any better than the one that was removed, only now you have a messed up gear selector cable for the effort.
Edit, addendum: an automatic transmission failure requires that the transmission cooler and lines be properly flushed. The torque converter must also be rebuilt or replaced. Otherwise, debris from the failed transmission can ruin the replacement unit.
sounds like the cost of repairs already exceeds the value of the car, so you have one or two alternatives:
buy another 1985 XJ-6 in working condition and save the other one for parts. You can get a nice, rust-free example, for around $2,500. Depends where you are located, but here in Florida, they are selling for little.
the other alternative is to spend more money and install a GM transmission, buying the required kit, transmission, and other parts from conversion specialists after you compare prices. Here's two specialists:
1) John's Cars in Texas: http://www.johnscars.com
2) Jaguar Specialties in California: http://www.jaguarspecialties.com
The benefit? you get a 4-speed automatic GM transmission, as opposed to the somewhat primitive 3-speed Borg Warner Model 66. Many have done this conversion and they say it makes the XJ-6 a better driving car. John's Cars is the best known of these specialists.
Jose
Jose
BrentGardner
29
Dec 16, 2024 12:13 AM
Aranon
Sep 1, 2015 01:00 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
