88 front seat removal HELP
Old Jun 15, 2018 | 08:44 PM
Ordinaryboy1986's Avatar
Default 88 front seat removal HELP
Is it possible to remove just the seat back of the seat? Bottom cushion was easy to remove but curious if you can just remove the seat back?
Thanks!
Old Jun 16, 2018 | 06:38 PM
Jose's Avatar
what model car is it? Is it a V12 Series 3 from 1988? or is it a XJ-40?
not familiar with the XJ-40 but in the Series 1, 2, and 3, the seat back can be removed but you must pull or remove the seat cushion first because there are two screws that are hidden by the seat cushion. Once you remove those two large screws, you push the seat back UPWARDS to release it from its top brackets.
Old Jun 23, 2018 | 04:04 PM
new mexico's Avatar
Thanks!
On my 78 xj I pull the bottom cushion out.
Then remove 4 bolts which hold the rail down , then everything should just come out.
walter
Joepizzo64
Sep 14, 2019 02:32 PM
Dave Baker
Nov 9, 2018 01:39 AM
green_hornet
Jun 12, 2018 09:26 AM
TreVoRTasmin
Aug 20, 2015 11:00 AM
rweber
Jan 9, 2013 07:00 PM
