AED conversion to manuał choke
Old Mar 14, 2020 | 04:52 PM
Daniel Nowak's Avatar
Default AED conversion to manuał choke
Hi guys,
I'm a owner of a nice series II Jaguar Xj6.
I have a little problem.
I bought a choke conversion to manual from the AED beacouse it doasn't work well.
Now it's a bigger problem, i've got no idea how to make it well running, there's two thinks pushing the air spring and fuel spring, have anyone have it it in car and could sens me a photo with meters this two thinks? I need to know the distance beetwen the rotor and the think what pushing the springs one od the air spring and one from the fuel spring.
Nobody in Poland want to help me :/
I send a photo what i'm looking for
Thanks Jag Lovers!
Old Mar 14, 2020 | 05:36 PM
Jose's Avatar
it would have been easier to istall an ON-OFF switch for the AED which itself is an electric choke.
Those of us with AED and carbs with older models like the 420 and S type of the 1960s install a ON-OFF switch under the dash to turn off the darned thing.
Another part you need to check is the OTTER SWITCH located before the thermostat. The OTTER SWITCH is usually what makes the AED malfunction.
I am not familiar with installing a manual cable choke but there are firms in the UK who understand how to do it in a Jaguar.
also you can try asking in the MK1 / MK2 / S type forum as the system is similar to the old Jaguar saloons.
Old Mar 15, 2020 | 05:19 AM
I've got older AED system, it's work with the hot air pipe from the exhaust, there's no otter switch.
The bimetal in AED died so i order from england this conversion to manual choke, i have installed it already in my car but now i need to know the distance beetwen this two thinks on the top on the manual converter, beetwen the think that pushing the springs from air and fuel. I'm looking for somehody who have it in his car worked fine so he can show me the distance have to regulated it.
Old Mar 15, 2020 | 05:22 AM
this two on the photo
Old Mar 15, 2020 | 06:44 PM
Jose's Avatar
see if this helps:
Old Mar 16, 2020 | 10:22 AM
Robert Laughton's Avatar
I suspect he's working on this Euro type of enrichment device. They all fail.
I'm guessing the 2 screws he has shown are the cut-in and cut-out adjustments.
Didn't the conversion kit come with instructions?
Rob
Old Mar 16, 2020 | 10:25 AM
Yep it comes with the instruction but there is nothing about adjustment, only showed how to mout it.
Old Mar 16, 2020 | 01:41 PM
Jose's Avatar
try SU Midel in Australia
http://www.sumidel.com/​​​​​​
Old Mar 22, 2020 | 05:42 PM
anjum's Avatar
You could try contacting these people and see if they are willing to help
they seem to supply the kit with the fitting and setting procedures
https://www.jagsparesinternational.c...t=%7C92:241%7C
PartsProjects
Sep 2, 2017 09:22 PM
petemohr
Mar 16, 2016 07:06 PM
monqc
Feb 1, 2013 04:58 PM
misty1
May 23, 2012 08:58 AM
hlgeorge
Jun 18, 2011 09:21 PM
