Auxiliary Electric fan modification
Old May 10, 2022 | 05:13 PM
bullittandy's Avatar
Default Auxiliary Electric fan modification
Wanted to share with the forum a modification I recently made to the AC system of my 1974 XJ12. I replaced the stock electric fan with a 10” S-blade fan, Spal #30100435.
This fan fits essentially perfectly within the stock shroud (after you cut off one set of mounting ears. I used the stud mounts of the fan, adding 1/4” bolts and drilling holes through the stock shroud to secure (sorry no pics). I only used two bolts to make install easier and added a strip of weather stripping to increase seal. I cut off the stock wiring connectors and added spade connectors for the Spal fan. I don’t know stock fans rating but it has to be less than this fans rating of 800 CFM.
v1rok
Jul 1, 2018 10:02 PM
Roger95
XJ40 ( XJ81 )
Jun 27, 2018 09:20 AM
Rhett
Oct 23, 2015 03:25 AM
rdssdi
Apr 26, 2015 10:09 AM
Terry
Apr 29, 2012 08:54 AM
