BD31972 - Buffer Pad
Old Sep 23, 2023 | 04:27 PM
yachtmanbuttson's Avatar
Default BD31972 - Buffer Pad
I can't for the life of me figure out where these two pads go on the trunk (boot) lid! Anyone know?
Thank you, Bill
BD 31972
Old Sep 23, 2023 | 04:42 PM
sov211's Avatar
The rubber pads do not go on the trunk lid. They are fitted to the body panel edge below the trunk lid. You should be able to see the holes for the screws. Difficult to see in this photo but you can see the edge of the rubber pad on the body opening directly below the V12 badge (just below the bottom edge of the trunk lid). Too bad the car isn't white!
Much more clear on this one - but the pads attach to the body, not the lid, with the narrow edge of the buffer at the outside.
Old Sep 23, 2023 | 07:50 PM
Larry Louton's Avatar
The purpose of the chip guards was to prevent the lid from touching the opening if the lid was to be slammed.
Larry Louton
Old Sep 23, 2023 | 08:45 PM
Ken Cantor's Avatar
Larry Louton
and we all know Jaguar boot lids are never to be slammed - an action reserved for uncouth mercedes and bmw’s of similar vintage - but instead are to be closed gently as befits their elegance.
Old Sep 24, 2023 | 06:20 AM
Jose's Avatar
outside of the rubber seal, at the bottom of the opening channel, one on each side of the center metal catch.
They are incorrectly ilustrated or positioned in the illustration.
Old Sep 24, 2023 | 08:31 AM
The purpose of the pads is to protect you from the Barbarians at your gate.
Larry Louton
Old Sep 24, 2023 | 10:50 AM
sov211's Avatar
And note:....this sticker should be on the black opening panel - and also note also the missing hyphen on the German line. This error was on the very late (1992) version (the is the trunk of #92/100):
Old Sep 24, 2023 | 05:39 PM
All good info - thank you. Does the screw fasten from underneath as the illustration shows? Does the "ramp" face forward or rearward?
Old Sep 24, 2023 | 05:58 PM
Chris Scott's Avatar
Forward....he said the narrow part faces rearward.
Old Sep 25, 2023 | 12:20 PM
sov211's Avatar
Installation is child’s play, or perhaps infants’ play. Small screw, fitted into the buffer from the top and into the panel. Absolutely no chance if error, but the narrow end goes to the outside, as stated.
The parts illustration is completely wrong and therefore misleading.
GordoCatCar
Aug 29, 2022 10:22 AM
2018XF25T
XF (X260)
Nov 9, 2021 10:35 PM
Long Islander
May 22, 2019 03:22 AM
Buckingham
Aug 20, 2016 01:28 PM
belsy
Jan 11, 2011 05:44 PM
