Car identification plz help
Old May 13, 2020 | 10:04 PM
xjtom's Avatar
Default Car identification plz help
Hi all,
I have an XJ6 S1 i'm working on the get running, i have basic information about the series 1 numbers but these i don't have so if anyone can fill in the blanks it would be greatly appreciated, the reason for this request is the car has a manual transmission (jaguar motor) but has an auto transmission console. Can't find a year stamp anywhere.
INFO> Car # 1L 12280 BW
Body # 4L 17811
Engine # 7L 23420-S (matches plate)
Gear Box # 15762
Old May 13, 2020 | 10:14 PM
Doug's Avatar
I'm no help, but the "BW" does confirm that the car was originally born with an automatic trans
Old May 14, 2020 | 12:42 AM
The Mekon's Avatar
Tom,
My car on the road is 3/73 manufacture Car no 1L 30422BW (auto)
My spares car is 3/71 manufacture Car no.1L 14484BW Body no 4L 22434
so indications are that your car is earlier than March 1971
Would appreciate a photo of your car.
Old May 14, 2020 | 01:16 AM
xjtom's Avatar
Doug/ Mekon,
thanks for your reply, as i suspected it was originally an auto, has a red jaguar motor in it which may have been a reco motor, were there any factory manuals around 1969/70? i almost got it going today but has a massive fuel leak at rear carb sandwich plate, think i'll be losing money on this one but determine to having it running right. Mekon, the car is a typical white series one, light blue interior, hand wind up/down windows
Old May 17, 2020 | 05:43 PM
xjtom's Avatar
well here's a good one for you all, this switch is in the ski slope & appears to be out of an MK 11, i'm guessing it was used as switch for the OD as there's no switch in the gear shift, this car keeps throwing curve ***** at me every time i go near it.............any comments?
WTF is this doing in the car....OD switch NOT auto it appears
Old May 17, 2020 | 07:22 PM
Doug's Avatar
Mysterious, yes.
It might have been installed for an entirely different purpose, unrelated to transmission.
But......
From the 50's to mid-60s Jaguar used an old Borg Warner design (DG250) that featured "intermediate speed hold". It locked the transmission in 2nd gear. You'll see that switch on any Jag of the era with an automatic transmission.
However, Jaguar dropped this transmission in the mid 60s, maybe 1966 or so? It may not have been dropped from all models simultaneously, however. I'm not sure. But, I've never seen or heard of an XJ6 with this older transmission. As far as I know all Series I XJ6s had the Borg Warner Model 35, Model 8, or Model 11. None of them had the intermediate hold feature as far as I know.
Let's hear what others have to say
Old May 17, 2020 | 07:24 PM
Doug's Avatar
Does the present transmission have over drive?
Old May 17, 2020 | 07:49 PM
Jose's Avatar
that switch is for the DG250 transmission used in MK-2, S type, and 420 Small Saloons
1959 to 1966.
it is a Second Gear Hold,
"in" means "ON", "out" means "OFF".
the hold switch is used in city traffic or when climbing a steep mountain when you don't want the
transmission to shift to Third Gear because the Third Gear in a DG250 transmission is like a Fourth gear, very tall for highway cruising at 100mph.
My '65 S type has it too. So basically the gears in a DG250 are First, Second, and Fourth.
the switch knob is incorrectly
oriented in the photo.
It should be East to West or Left to Right, instead of North to South or up/down.
Old May 18, 2020 | 03:39 AM
xjtom's Avatar
Hi all again,
i've had a better look today & the switch has been used as an on/off for the OD on the manual gearbox instead of in the shift button........
Old May 18, 2020 | 05:43 AM
Jose's Avatar
Originally Posted by xjtom
Hi all again,
yes it is obvious since the XJ-6 never had that Speedhold switch from new.
looks like the owner or the shop who did it were familiar with previous Jaguar model. parts.
Old May 18, 2020 | 09:30 PM
xjtom's Avatar
Hi all,
quick update about this XJ6 S1, i discover that the pass/side rear end has broken away from the mount rubbers so after some "friendly" conversation with the guy i got the car from he agreed to take the car back & full refund, i have lost a couple of hundred dollars & labor on it but better than a couple of $k......better luck next time i hope.......
Pier
Aug 21, 2021 01:16 AM
Pkl
Jul 8, 2017 05:18 PM
Awillie
E type ( XK-E )
Mar 29, 2016 04:05 PM
Splinter Chief
Jun 29, 2015 09:36 AM
shanec
Oct 6, 2012 09:50 AM
