Climatron
Old Jan 8, 2021 | 10:26 PM
Barcho's Avatar
Default Climatron
Anyone familiar with this part. I encountered it when I had the drivers side console area open to remove the heater core. The label says "Climatron; engineered to suit Jaguar". It has a multi wire cap plugged into one end and a single ground wire at the other end. Is this a substitute for the climate control amplifier? There is another multiwire cap that is disconnected. All functions of the climate control sysem work.
Barcho
'86 XJ6
Old Jan 8, 2021 | 11:59 PM
Doug's Avatar
That's a re-engineered aftermarket replacement for the climate control amplifier.
The original looks like this and may well still be residing, unused and disconnected, behind the tangle of wires
Doug's Avatar
Original amplifier
Old Jan 9, 2021 | 07:34 AM
yachtmanbuttson's Avatar
I have a Climatron in my 1075 XJ6C and it works just fine.
Old Jan 9, 2021 | 09:10 AM
davidboger's Avatar
It's not unusual to leave the original in place when it dies. They are a PITA to get out.... If it's working I'd definitely just roll with it ... Just tuck it behind the kick panel when you put things back together...
Gary at JagAire has the best replacement amp these days. He builds them to the original spec, and original size and shape... I think the others have been out of production for some time now.....
David
shop.EverydayXJ.com
Old Jan 10, 2021 | 07:18 PM
Gary also has refurbished and rejuvenated Servos should someone have the need.
I can say they are a thing of beauty, and a Lot quieter than one 45 years old.
Old Jan 11, 2021 | 01:08 AM
Greg in France's Avatar
I used to love hearing the reassuring mechanical whirr of my servo; sadly I cannot hear that any more as old age has started to bite! Delanair mark III owners do not know what they are missing!
Old Mar 17, 2024 | 01:49 PM
leo_denmark's Avatar
Hi
I have mounted a Climatron in my XJ-S 5-6 years ago. The fuse failed (without looking burned in any way). It didn’t have any amperage marking, so I crossed my fingers and replaced it with a 5A fuse. That has now burned, so I wonder if someone here knows what fuse I should use ?
BR Leo
Old Mar 17, 2024 | 05:38 PM
Andy T.'s Avatar
The fuse should be 1A
As yours has blown twice now, it indicates a fault with either the servo or the amp. Most likely scenario is the servo has jammed, possibly due to one of the rod linkages becoming displaced.
muttony
Apr 7, 2019 10:30 PM
Slow
Apr 13, 2016 11:51 PM
Wascator
Apr 14, 2014 04:25 PM
matjohns
Nov 16, 2010 03:22 PM
