Codes P0727 & P1775 Mech says unrepairable?
I'm haveing the same problem. did you have any luuck when you checked the EGR? I checked mine and it seemed to be opening and closing fine. I did however remove and clean the crank sensor.................after that it went from running 5-7 minutes to running almost 30 before it conked off. I'm replacing the crank sensor tonight (had to order it). I'll post how it turns out. Thanks to all!
philwarner
25
Jun 26, 2021 05:43 AM
derek15301xjr
Oct 20, 2015 07:39 PM
