Crankshaft bolt
Old Jun 10, 2016 | 05:07 AM
MalnFaye's Avatar
Default Crankshaft bolt
I am trying to find a socket to fit on the crankshaft bolt on a 4.2 engine. Can anyone tell me the size of the bolt.
Sort of related, how is the lower section of the radiator cowl attached?
Any thoughts appreciated.
Old Jun 10, 2016 | 12:13 PM
Tar's Avatar
Tar
I seem to remember it's 1-5/16". Someone else will confirm or correct…
Andrew.
Old Jun 10, 2016 | 02:28 PM
sanchez's Avatar
I use a 33mm socket on my Series 3. Fits nice and snug.
Old Jun 10, 2016 | 03:23 PM
Tar's Avatar
Tar
Close enough! 🙂
Old Jun 24, 2016 | 04:08 PM
Series1fan's Avatar
Andrew is right.
Would just add: When using it be careful not to let your hand keep hitting the expansion tank hose (assuming stock set up). It's pretty hard to keep the spanner on the crank nut so it's easy to hit that hose as there is little room. Issue is the nipple is copper and has a weld onto the expansion tank which is pretty delicate. It's really easy to break that weld (Yes, did so) and then you'll have coolant leaks until you get it really nicely re-done.
dwgates
Oct 23, 2018 10:57 PM
larney
Jun 2, 2016 10:03 PM
andyXJR
May 24, 2016 02:09 PM
andyXJR
May 18, 2016 09:08 AM
Rickxj6
May 15, 2016 05:51 AM
