Cruise Control series 2 auto.
Old Apr 22, 2015 | 09:05 PM
Daf11e's Avatar
Active Streak: 120 Days
Default Cruise Control series 2 auto.
Hi all just wondering if anyone else has this cruise control set up on their series 2 auto.............just wanted to see how old it would be?
Also it works just fine....
Old Apr 22, 2015 | 11:22 PM
I wouldn't mind having one of those!
I don't have any of the mechanism for a cruise control, only the button on the shifter tower.
Old Apr 22, 2015 | 11:35 PM
Daf11e's Avatar
Yeah Lnr it really makes a difference, just wondering how old....I can find them on the net and it appears similar ones were used in the old muscle cars in your neck of the woods.....
Old Apr 25, 2015 | 04:24 AM
Daf11e's Avatar
No one has an aftermarket cruise control?
Old Apr 25, 2015 | 08:47 AM
I haven't actually looked into it although I imagine they will be hard to find because every car I know of has factory cruise control.
I wouldn't think under those conditions there would be a market for add-ons.
Later I might look into it though, but not right now. We're already virtually rebuilding the whole car, having spent enough money we've bought it all over again.
Old Apr 25, 2015 | 09:37 AM
JagCad's Avatar
Thanks for the diagram. I have similar ones, but, I can never resist adding to my Jaguar lore!!
Somewhere out there, after market kits new or used or NOS. Pretty slick. I added a lot of "gadgets" to my "Plain Jane" 79 IHC Scout II. One was CC. It shared a "signal generator" with the after market trip computer I installed. A magnet wired to the drive shaft and a pickup on a bracket nearby. And, the bellows that pulled the throttle was a tin can ala brake booster. No leak issue. The connection wasn infin itely adjustable ball type chain.
If on really wanted to, one could rob a later GM of it's CC. They freature an electronic throttle pull ala "by wire, sorta". slick little units.
I've never reconnected the cc in the Jaguar. Actually, I am using the brake pedal interrupt as the torque converter release!!
Elinor. if you are interested, loo9k and see if there two similar switches behind the brake pedal. they look alike, but function exactly opposite. The other CC interrupt is on the shift tower. a micro switch la starter interrupt.
Still a bit puzzled over my geometry lesson on shim adjustment for upper control arms!!
Carl
Old Apr 25, 2015 | 05:40 PM
xjtom's Avatar
Daff,
I have 2 of those units, one i fitted to my S2 & the other in my Ford XB, i've had the unit in my XB since 1996. the one pictured i have that control in my XB, the same unit but a slimline control in my S2 jag. wouldn't drive without one, went to Melbourne xmas 13/14, perfect for the Hume H/way.
These units were make in Sydney early to late 90's, the type you have is the pre efi setup, once in a while you need to clean the actuator valve in case of dust build up so it won't jam on..........i'd be interested in comparing where it was set up........tom
PS. Daff, i'm going for a drive with the club today to warragamba dam, about time the rain slowed up.
Old Apr 25, 2015 | 06:31 PM
Daf11e's Avatar
Have a nice run.....good luck after the hail last night.
Skeeter
Sep 17, 2015 08:15 PM
edtexas
Sep 4, 2015 08:20 PM
XFR_Gold
Sep 2, 2015 12:24 PM
