Daimler double six 5.3
Old Sep 29, 2015 | 05:12 AM
muntasarz's Avatar
Exclamation Daimler double six 5.3
Hi Friends,
I have just bought my neighbors Daimler Double 6 , it was parked for two years.
So I’m planning to fix it soon & i have the following questions:
What is the correct battery for it as i have doubts on the installed one?
What can i know from the VIN number (SAJDDJLW4CR484..) ?
How to remove the drivers seat for renovation ?
Regards,
Old Sep 29, 2015 | 05:51 AM
Firstly, Welcome to the forum.
When time permits, please do an intro in the "New members area".
Where is Muscat????. Different markets have different stuff.
Also what year is the Daimler?. Different versions of the 5.3 along the time frame.
Old Sep 29, 2015 | 02:37 PM
Tar's Avatar
Tar
Muscat is in Oman, Middle East.
The "484" suggests it is a 1988 model.
As to the particulars, my six-cylinder uses a group 34, but obviously the 12 may have different needs. Generally though, the biggest battery that will fit (the greatest CCA) is the best choice.
Seat, a screw on the front (under your knees) releases the lower cushion. Then, four bolts should remove the rest from the floor. Don't forget to unplug the power leads for the motor.
Hope this is helpful.
Andrew.
Old Sep 29, 2015 | 02:38 PM
muntasarz's Avatar
Wink
Hi Grant Francis,
This Daimler is 1990 left hand Japanese imported vehicle.
Muscat is the capital of Oman.
Old Sep 29, 2015 | 02:45 PM
muntasarz's Avatar
Cool
Sorry i have mistyped the VIN number, the correct number is "SAJDDJLW4CR4834.."
Old Sep 29, 2015 | 08:20 PM
Thanks for that.
As Andrew has said the largest physical size that will fit the tray, and CCA of around 620+.
Down here it is known as a N52, or N53 with the terminals reversed.
Watch the height at the terminals, coz some batteries can be too high, and when the bonnet is shut, sparks fly.
The seat should be secured by 4 bolts/setscrews. Usually slide it ALL the way back for the front 2, and ALL the way forward for the rear 2. Then a few electrical connectors underneath depending on seat heaters, motors, etc that may be fitted.
oldjaglover
Dec 25, 2024 04:33 PM
SCMike
Nov 25, 2015 07:55 AM
LnrB
Oct 13, 2015 12:45 AM
vicom
Sep 17, 2015 03:32 AM
