Dismantling throttle pedestal on V12
Old Apr 28, 2025 | 08:44 AM
Billbuck's Avatar
Default Dismantling throttle pedestal on V12
Hi. I'm.having trouble with the central pedestal that controls the opening of the throttles on my 1977 pre HE XJ12. It is not fully returning to the stops under the force of the return spring, causing a very high idle.
I want to disassemble and clean it and replace the return spring, but my Haynes manual doesn't cover this. My question is- should I be aware of anything when taking it apart and reassembling?
Old Apr 29, 2025 | 01:27 AM
Yep.
Remove the TPS (Throttle Position Switch on yours) prior to removing the 2 hex screws and pulling the plate/shaft out.
Generally, when that plate is out of the way, a few drops of ATF on the innards, leave it soak for a beer or 3, and all is usually OK.
I have never replaced that spring, they seem robust, just some lube every few years or so, and they be happy.
Old Apr 30, 2025 | 10:38 AM
garethashenden's Avatar
I like the use of beer as a unit of time.
Old May 1, 2025 | 02:00 AM
HA,
Is there a better way???
Wife sees you sipping, and asks the obvious.
Reply :"just waiting and need to pay attention", job done.
nickr76
May 2, 2025 05:03 PM
AndreasXJS
Jan 31, 2024 07:24 AM
ptjs1
Jul 6, 2021 11:16 AM
scuby
Jun 26, 2020 03:20 AM
AristoCat
Dec 6, 2014 11:47 AM
