Throttle body set up specs?
Old Apr 23, 2025 | 07:48 PM
nickr76's Avatar
Default Throttle body set up specs?
Anyone have the FSM procedure to set throttle bodies?
I want to start from scratch, make sure everything is set correctly.
not just the throttle plate, the entire mechanism. From cable to butterflies and everything in between.
thanks
Old Apr 24, 2025 | 07:28 AM
Vee's Avatar
Vee
Many model years, quite a few engines to choose from as well over that same time span...
Old Apr 24, 2025 | 05:21 PM
nickr76's Avatar
mines a v12, I found the directions in another post. Seems all the v12 are the same.
Old Apr 25, 2025 | 06:24 AM
Vee's Avatar
Vee
there’s a 6.0L v12 and a 5.3L and a much rarer TWR version as well.
Theres also a HE and a preHE.
Old Apr 25, 2025 | 06:44 AM
Doug's Avatar
I don't know what the manual says but I've attached a good write-up from Grant...which is similar to my method
Old Apr 25, 2025 | 03:32 PM
nickr76's Avatar
and the specs are all the same.
Old May 2, 2025 | 06:38 AM
Billbuck's Avatar
thanks
There is a good video on YouTube from 'livng with a classic' who is a Canadian guy who has many of these cars. This goes through the whole process. Also check the rubber grommet/bushes at the bell crank to spindle connection are in good shape. If not I think he has a link to someone in eastern Europe who has remaufactured these in a much better(Teflon?) material.
Old May 2, 2025 | 07:20 AM
garethashenden's Avatar
Adam, Living with a Classic, is Swedish. It’s still the frozen north, but not quite the same as Canada.
Old May 2, 2025 | 11:18 AM
Billbuck's Avatar
I stand corrected. I was going on his accent and the snow!
The bushes I mentioned are Teflon PTFE, are from an enthusiast in Lithuania and are available on Ebay.
Old May 2, 2025 | 05:03 PM
944play's Avatar
Had I known about the upgrade items from jag-improver when I was needing throttle spindle bushings, I would have sprung for them.
What has been working for me are oiled sintered bronze flange bushings, part number EF050806. They're cheap and available stateside. The only downside is that the bushing's OD is 1/2" and the hole in the bracket is a tiny bit smaller. I elected to sand down the bushing rather than drill out the bracket, but I suppose either way can result in a nice press fit.
warrjon
Apr 3, 2026 03:45 AM
MWC
Jun 16, 2024 11:06 PM
fredd60
Mar 10, 2019 09:01 PM
felinecat
E type ( XK-E )
Aug 15, 2015 09:58 AM
XJR-0220
Nov 24, 2010 06:21 AM
