Door Hand Clips
Old Dec 9, 2023 | 06:31 PM
adenshillito's Avatar
Default Door Hand Clips
Any collective wisdom, on the chrome handle thing designed by Satan and impossible to install 96% of the time without harm.
Old Dec 9, 2023 | 07:25 PM
kudzu's Avatar
Hi,
1 Slide the chrome finisher piece up on the handle as far as it will go without damaging the covering.
2 Place the metal plate over the bolt with the bent up wings facing up and away from the door handle
3 Put end of door handle over bolt and install lock washer & nut
4 Slide finisher down handle and snap over wings on metal plate
Cheers,
Brian
Old Dec 9, 2023 | 10:08 PM
ukborn's Avatar
I remove the 3 screws underneath the pocket first and the one under the armrest allowing some movement in the holding slot. Then using a plastic panel tool pry it off carefully. Photo attached shows the reversal install
Installing the chrome finisher
Old Dec 9, 2023 | 10:10 PM
ukborn's Avatar
Apr 2, 2024 05:32 PM
italcarnut
Oct 22, 2023 07:36 AM
gibbon
Nov 13, 2017 08:38 AM
XxSlowpokexX
Feb 18, 2015 07:08 PM
ruslan35
May 15, 2007 10:06 AM
