Broken Door Handle Question
Old Feb 15, 2015 | 08:08 PM
XxSlowpokexX's Avatar
Default Broken Door Handle Question
Ive searched and came up with little info. Can I just remove the door handle chrome piece itself? Seems mine cracked today and being cars custom painted well....Looks like others have done the same but none has followed up. Always something
Old Feb 16, 2015 | 03:20 AM
Do you mean the chrome interior door handle or do you have a chromed lift on the outside handle?
Old Feb 16, 2015 | 08:13 AM
ccfulton's Avatar
In either case, you won't be able to remove it from the outside and not without removing the assembly from the car first.
Door panel comes off and then it's either bolts for the outside one, or a slip connection for the inside.
Old Feb 17, 2015 | 06:10 PM
sorry guys. outside chrome handle. I know to remove the handle assembly I need to remove door panel etc. I was curies as to just replacing the chrome handle portion and not entire piece as I have custom paint that wont likely match
Old Feb 17, 2015 | 06:45 PM
ccfulton's Avatar
Found a picture of a handle and looking at the back of it I imagine you can replace just the chrome part if you take it all apart.
I doubt you will be able to buy just the chrome vs the whole assembly, but you probably expected that part.
Old Feb 18, 2015 | 07:09 AM
The lift handle has to pivot on a rod (arrowed in red) which should knock out with a drift.
Old Feb 18, 2015 | 04:31 PM
After seeing the photos Ill just go pick one up and see what I can do..Be it pin rivet or threaded rod Im sure I can get it to work. Cant believe it just snapped like it did
Old Feb 18, 2015 | 07:08 PM
It was a regular fault with the early XJ40's but you look to have been unlucky with the same thing happening on an XKR - it's usually the latch microswitches that fail on this model!
99xk8guy
Sep 29, 2025 10:51 PM
Dz1rfj
Jul 17, 2018 10:29 AM
XJsc-guy
Nov 23, 2015 01:56 PM
Dz1rfj
Sep 16, 2015 03:44 PM
hoodun
Sep 7, 2015 07:02 PM
