Door-to-window seal replacement
Old Nov 12, 2015 | 08:22 AM
NathanDD6's Avatar
Default Door-to-window seal replacement
Hi all
The door-to-window rubber seals on my car have shrunk and are not sealing against the glass anymore.
Has anyone ever replaced these things? How does one go about it?
Many thanks
Old Nov 12, 2015 | 09:16 AM
XJ6Paul's Avatar
I replaced the one on my driver's door recently. It was dry and cracked. I bought the replacement from rockauto:
https://www.rockauto.com/catalog/mor...789&cc=1178074
It says you need 2 per door, but that's incorrect. I purchased two and one is long enough to do a single door, front or back.
I took the door card off, put the window down, then used needle nose pliers to slide and pull the old strip/beltline out. The lower edge of this beltline has a channel that holds it in place. Then I sprayed some silicone spray on the new strip and slid it into place. Little tedious, but didn't take long.
Old Nov 12, 2015 | 09:50 AM
NathanDD6's Avatar
Brilliant! Thanks for the response.
What are you referring to when you mention the "door card" I've never heard that one before.
Thanks again.
Old Nov 12, 2015 | 10:41 AM
Jose's Avatar
door cards = the upholstery panels which cover or "finish" the interior side of the doors.
Old Nov 12, 2015 | 10:51 AM
XJ6Paul's Avatar
Exactly, thanks. I've heard them called door cards, inner door panels. Jaguar's official name is door casing, item 3 in the photo.
The rubber/felt strip that rubs against the outside of the window is item 5, Door Waist Seal, part BD464586. I was happy with the URO part I received from Rockauto.
Door Casing-Front - Parts For Series III Saloon | Jaguar Heritage Parts UK
Old Nov 12, 2015 | 10:57 AM
Jose's Avatar
for some reason that door panel does not look like an XJ panel.
Old Nov 12, 2015 | 11:16 AM
NathanDD6's Avatar
Many thanks Jose and WinstonWolf, I'll see to that when I can.
Old Jan 27, 2025 | 08:20 PM
72JagroletXJ's Avatar
I see this answer if from 15 years ago, but it was what I was looking for, so if you're still there, THANK YOU!
Old Jan 28, 2025 | 12:39 AM
Jose's Avatar
how time flies, i'm still here !!
Zazzy
Jan 29, 2023 08:44 PM
Papelione
Jun 23, 2016 07:05 AM
Monsees
Nov 12, 2015 09:03 PM
pab
Nov 10, 2015 08:46 AM
Mr seaside
Nov 7, 2015 03:50 AM
