ECU compatability
Old Dec 15, 2024 | 12:51 AM
Bones57's Avatar
Default ECU compatability
My 1992 Vanden Plas V12 needs a new ECU, I can find one online with the identical part number DAC 6335 84562H but is for a 1989, the only difference is the build date. Would this work in my car without reprogramming it. Thanks
Old Dec 15, 2024 | 03:10 AM
Daf11e's Avatar
Hi there your XJ is actually referred to as an XJ40, this section is for XJ6 & XJ12 series I II & III.
for help just follow this link…https://www.jaguarforums.com/forum/xj40-xj81-25/
When time permits post an introduction in the new members area…good luck!
Old Dec 15, 2024 | 06:21 AM
Doug's Avatar
I can't think of any reason there would be a problem.
Old Dec 15, 2024 | 06:26 AM
Doug's Avatar
A '92 VDP V12 would still be a Series III !
Old Dec 15, 2024 | 10:58 AM
Bones57's Avatar
thanks I did not know that it was considered an XJ40 or a series lll
Old Dec 15, 2024 | 12:38 PM
sov211's Avatar
Yes, that unit will work on your 1992 model….that car does not have the bevy of electronic nannies that the later designs do. And what number/100 is your car? (The V12 VDP was a Canada-only model and for 1992 only 100 were built).
Old Dec 16, 2024 | 11:28 AM
Bones57's Avatar
Great thanks. It’s #85 if I remember correctly, car is new to me and I’m not near it to check. Out of curiosity would an ECU with different part number also work, just in case this one doesn’t work.
Old Dec 16, 2024 | 02:12 PM
sov211's Avatar
Ah…well, an ECU with a different part number may be a different animal. What is making you think the ECU is defective? An issue with the V12 ECU is super-rare.
rgp
Apr 1, 2024 01:53 PM
brinny
Dec 31, 2016 06:41 AM
Thang Nguyen
Aug 28, 2016 10:42 PM
mtotrainer
Jul 30, 2011 08:19 AM
BaDAss03STR
Sep 10, 2008 02:57 AM
