Engine crank breather filter C44410
Old Nov 28, 2024 | 01:23 PM
Dakota.'s Avatar
Default Engine crank breather filter C44410
I’m curious as to what purpose filter C44410 serves. This is filter located under the breather cap. Is it something that routinely needs to be replaced? As shown below in diagram
Breather filter
Breather filter
Old Nov 28, 2024 | 02:01 PM
Jagboi64's Avatar
I believe it's an oil coalescing filter, causes any fumes to condense and drain back into the crankcase. It's a metal piece, never needs replacing. Maybe cleaning occasionally, but that's not generally a routine thing.
Old Nov 28, 2024 | 10:22 PM
Dakota.'s Avatar
Thank you for this information! Exactly what I needed to know.
Old Dec 5, 2024 | 04:00 AM
TomRamirez's Avatar
Yes, thank you so much for sharing the information.
Old Dec 5, 2024 | 10:40 PM
David84XJ6's Avatar
I can't quote a reference, but thought it was a flame arrestor to prevent lean backfires in intake system from going into the crank case???
The vertical screen coalesces the oil fumes into oil that drains back to block.???
Rgds
David
Old Dec 6, 2024 | 06:04 AM
Doug's Avatar
I've not heard the flame arrestor thing, but that doesn't prove anything.
Anyhow, anyone without it shouldn't be too surprised. Jaguar eventually stopped installing them on the Series III cars. I can't remember when, offhand. 1985? I'm sure there's a TSB for it but it would take a lot of slogging to find it.
Cleaning both screens....which is seldom ever done....isn't a bad idea. If clogged the resulting increased crankcase pressure will worsen any oil leaks.
Old Dec 6, 2024 | 03:26 PM
David84XJ6's Avatar
P/N 603330
Genuine OEM 603330 - Land Rover Flame trap-crankcase breather (603330) part for Discovery 1 1989 - 1998 (from Fa393361 To Wa799999) Classic, Range Rover Classic 1986 - 1991 (to Ha610293) Classic, Defender 1987 - 2006. Authentic Land Rover Part.
Not a direct replacement, just showing some one thought this was a good idea at some time.
Rgds
David
Old Dec 21, 2024 | 12:13 AM
MiaJames's Avatar
Spoiler
Breather filter
Breather filter
Thanks for the diagram tho, you saved my day.
MRomanik
Sep 2, 2022 09:50 AM
jerseydevil
F-Pace (X761) / C-X17
Jul 12, 2019 11:38 AM
dstjohn
Jul 8, 2019 11:46 AM
Jagst
Feb 20, 2016 05:25 AM
benitothebandito711
Jan 10, 2009 03:33 PM
