Engine Number Decode
Old Jan 10, 2025 | 06:44 PM
Speedster's Avatar
Default Engine Number Decode
Have a V-12 engine with the following numbers stamped on the rear of the engine. X8S39882SA and AC1962 and BM865X and 279 and 180. Has center distributor and fuel injection. Trying to determine which manual flywheel to purchase. Up to engine number engine 128477 uses flywheel EAC8192 After that it uses flywheel EBC1832. Looked at Quick Links numbers and they don't make any sense.
I do not have a vehicle. I simply purchased the engine from a fellow that said it came out of a 1986 XJS. I'm in the process of building a Speedster / Race Car
Old Jan 11, 2025 | 03:51 AM
Greg in France's Avatar
8S39882SA
I am pretty sure that is an XJS HE engine number. I think, repeat think, that the S stands for a USA spec engine (lower CR than UK and RoW). See second poost in this thread:
https://forums.jag-lovers.com/t/engi...-engine/418195
This is my 1985 Uk spec XJS number:
Old Jan 11, 2025 | 08:19 AM
Speedster's Avatar
Greg in France Thank you for information. Now my engine number makes sense! Based on your number my engine is a little later and pretty much confirms it is a 1986 engine. In tracking down the part number for the manual flywheel, I purchased an official Jaguar Parts Catalog for 3.6 / 5.3 Litre. I entered some flywheel part numbers with the above question. I just realized I made a mistake. I was looking at the 3.6 Litre manual flywheel information. I searched every page and now realize there is no part number listed for the 5.3 Litre flywheel! Re-checking the catalog I now see it is for 1987 and newer models. I need to find out the first year a manual transmission was offered for the V-12 in the XJS. Once I find that out, I can then purchase the correct parts catalog. I do have request out in another area asking for help finding that flywheel part number.
There are several vendors out there selling flywheels. I want to ensure I get the correct one in terms of number of teeth and alignment with the starter. Thanks again for your help. Al in Michigan
Old Jan 11, 2025 | 08:33 AM
Doug's Avatar
The "X" is a bit of a mystery. But 8S39882 would be an HE engine
7Sxxxxx 5.3 Liter E-type
7P1001 5.3 Liter XJ12/Daimler Double SIx Series 1 w/carburetters
7P4000 5.3 Liter XJ12 & D6 Series 2 w/carburetters
7P25001 5.3 Liter XJ12 & D6 Series 2 w/fuel injection
7P42300 5.3 Liter XJ12 Series 3 Pre-HE (suffix ? = 9:1, suffix HA = 10:1)
7P45001 5.3 Liter XJ12 Series 3 HE
8S1001 5.3 Liter XJS non-H.E.
8S18001 5.3 Liter XJS H.E.
Old Jan 11, 2025 | 08:43 AM
Doug's Avatar
The manual trans was not offered or used behind the HE V12. The last manual trans XJS V12, of only about 350 total, was circa 1979-80, Pre-HE
Looks like the flywheel would be C37105. Google "Jaguar C37105 flywheel" and see what comes up
Whether or not you can use this flywheel on an HE engine is another question. I dunno.
Old Jan 11, 2025 | 09:33 AM
Speedster's Avatar
Doug Thank you, I think I finally have the right part number ! Google came up with flywheel from Martin Robey Sales UK same p/number at 607 #'s. Has same diagram as you provided. Driven man has same flywheel for $399 US. I believe I have come to the end of my flywheel search. Now onto the Bell Housing and determination of a transmission. NO doubt it will be GM or Ford Tremec 5 speed.
Thanks again Al Ruckey Michigan
Adam Deermann
Aug 21, 2024 10:26 AM
jaguar1966$
E type ( XK-E )
Feb 10, 2023 09:20 AM
mu2rick
E type ( XK-E )
Mar 26, 2018 09:24 AM
Gatsby
Sep 6, 2015 11:52 AM
Gippsland
Apr 15, 2013 05:11 AM
