engine swap
Old May 10, 2012 | 07:48 AM
guitarranger11's Avatar
Default engine swap
I was thinking of putting a motor and tranny in my JAG but my question is my car is a 87 xj6 series III and the motor would come out a 82 series III and I was wondering if those 2 years are compatible with each other. Thanks in advance
Old May 10, 2012 | 08:20 AM
Doug's Avatar
The basics are the same.
A couple possible differences would be with or without air injection (an '87 would have it for sure) and early versus late cooling system: water pump, water rail, cooling fan, etc.
Old May 10, 2012 | 12:50 PM
Fraser Mitchell's Avatar
Hmmm... An 82 engine sits in the disaster zone for block cracking between the bores. Your 87 engine will have the slotted block which eliminated this. Why do you want to swap ?
Old May 10, 2012 | 11:57 PM
I came across a motor and tranny for 200 and was gonna grab it and rebuild it. Is this a good idea or should I pass on it. I'm new to Jaguars motors and I appreciate all of you and your knowledge
FrickenJag
Jun 16, 2025 02:15 PM
cissdm
May 3, 2016 06:02 AM
sogood
Sep 15, 2015 07:35 AM
bdboyle
Sep 4, 2015 06:16 AM
Bowman
Sep 3, 2015 03:17 PM
