Fan motor relay
Old Jul 13, 2013 | 12:14 PM
gray cat's Avatar
Default Fan motor relay
having a tuff time finding a replacement relay ( engine cooling fan motor relay) the orange color , 5 prong . is it possible to use a substitute relay to do the job ??? it's for a 86 xj6
Old Jul 13, 2013 | 01:38 PM
OliverB's Avatar
You mean the red relay just above the cooling fan? Mine smokes and blows the fan fuse when I put one in. Also looking for a replacement. Most stores have nothing. Will advise if I find one.
Old Jul 13, 2013 | 02:16 PM
gray cat's Avatar
yup that's the one , I've looked and looked , if you can find one I beleive they are $100
my old one may work I will find out tomorrow
Old Jul 13, 2013 | 02:29 PM
jimbov8's Avatar
Hi Gray cat,
Bit confused as to why you require a relay if you think the one you already have may work.
Do you have a overheat problem or are you not seeing the fan operate?.
Old Jul 13, 2013 | 02:50 PM
OliverB's Avatar
You've gotta be kidding me? That's ridiculous. Autozone here in SA have the relays at around the equivalent of $4ea but they just don't have one with the right layout.
Old Jul 13, 2013 | 05:51 PM
gray cat's Avatar
when we took out the radiator , the relay smoked and a one of the stems is now loose. We are assuming the relay is now toast. once the radiator is back in we can test it
Old Jul 13, 2013 | 09:22 PM
Doug's Avatar
A typical "Bosch Style" accessory relay with the usual 30-85-86-87-87a terminal designations will work. Very common.
Old Jul 13, 2013 | 09:28 PM
gray cat's Avatar
Thanks Doug ! I will send you a pic of the gray cat , which is now two tone silver / gray patterned after a 58' Rolls-Royce
Kevin O
Old Jul 19, 2013 | 12:40 AM
OliverB's Avatar
Thanks Doug. Will pick one up and see if it solves my non-operational yet brand new auxiliary fan.
abonano
25
Sep 25, 2015 10:43 AM
eurotire
Sep 18, 2015 07:27 AM
Tipptone
Sep 16, 2015 07:39 AM
1100me
Sep 7, 2015 06:26 AM
XJsc-guy
Sep 2, 2015 11:43 AM
