Fill neck plate
Old May 15, 2016 | 02:07 AM
adenshillito's Avatar
Default Fill neck plate
Is there a standard industry name for the triangular 3-bolts fill neck plate at the top of the engine in Series 2 cars? its the one the radiator cap screws on to.
she has a leak, Jim, canna take the pressure.
rounded edge triangle base plate and three bolts.
Old May 15, 2016 | 02:52 AM
o1xjr's Avatar
That is the header tank filler neck. It does not have a pressure cap, it has a blanking cap on it. I filed the top rim of mine to make it flat then made a thicker rubber gasket to seal it.
Part number C.30998
http://www.gumtree.com.au/s-ad/mosma...eck/1063093612
Old May 20, 2016 | 04:29 PM
XJ6Paul's Avatar
I had a small leak at the blanking cap on my SII and replaced it with one made by Waxstat, looks similar to the one in Clarke's photo. The Waxstat cap has a thicker rubber gasket than the cap I replaced, and it no longer leaks.
However, I do still have a leak from under the triangular plate. The parts diagram indicates use of a triangular shaped gasket up to engine number 8L14791 and then an o-ring after that. My engine number starts 8L165xxx, but I had a gasket and no o-ring. My plan is to take the tank off to clean up the neck area, then put in a new o-ring and use rtv or permatex between the triangular plate and header tank.
Attached Thumbnails Fill neck plate-sii-thermo-housing.jpg   Fill neck plate-header-tank.jpg
aholbro1
Feb 14, 2021 01:51 PM
JigJag
Jun 2, 2017 02:53 PM
oldemacdonald
Apr 18, 2016 07:31 PM
oldemacdonald
Apr 14, 2016 01:36 AM
springer
Mar 28, 2016 01:37 PM
