First time battery hook up after 20yrs..xj12
Old May 10, 2024 | 10:07 PM
Jeffkrell's Avatar
Default First time battery hook up after 20yrs..xj12
So hooked up a battery, showed .5A ignition off.
ignition ON. only IGNITION displayed on annunciator panel.
radio, clock, windows, door locks, climate control fan, wipers, all had power and functioned.
was able to engage starter (pistons lubricated) as well.
no headlights and no blinkers. No power to fuel pump feed line…
where to go next ? I’d like to have the headlights and blinkers functioning. No power at headlight fuses.. all fuses cleaned and tested.
thanks
Old May 11, 2024 | 06:54 AM
Malcolm Ridgway's Avatar
thanks
Electric gremlins - check all the bullet and spade connectors- likely corrosion.
Old May 11, 2024 | 08:30 AM
slofut's Avatar
What year car? Annunciator panel doesn't sound like a ser 3. Did they make xj40's with a v12? Or maybe the indicator panel between the tach and speedo on a ser 3 is indeed called an annunciator panel. Not trying to be jerk, I immediately thought of the electronic panels on each side of the column on an xj40. Whole different car...
Old May 11, 2024 | 11:08 AM
Jeffkrell's Avatar
Oh Sorry. 1977 xj12 injection NA. I’ll clean all connections I can access. Did a few already.
small wire wheel on dremel and rubbing alcohol. It’ll take a while. Oil pressure light should be easy to trace..
Old May 11, 2024 | 06:04 PM
slofut's Avatar
20yrs sitting my first thoughts are clean the light switch and ignition switch with D3/D4 spray cleaner or spray electronic cleaner from the parts store first. Spray into switch and cycle a few times, bet things start coming to life.
You'll probably want to do this to all the switches at some point.
Old May 11, 2024 | 08:07 PM
Jeffkrell's Avatar
Got lights to work powering directly at relay. Worked. Powered them thru light switch no luck. Brown + and ground didn’t work…. It’s fun I’ll figure that out eventually. Lots of cleaning to do. Connections are dirty ect…
I have a schematic so it’s easy to trace. I hope the ecu will come alive..
Old May 11, 2024 | 09:53 PM
1977XJ5.3's Avatar
Ensure all your grounds are clean and tight.
Old May 12, 2024 | 07:38 AM
slofut's Avatar
Exactly! Clean the switch...
FarmerJohn
May 1, 2019 08:56 PM
Bruce Caulley
Sep 30, 2013 07:20 AM
bracester
Sep 26, 2012 07:43 PM
htkenan
Jan 19, 2009 10:55 PM
