Fuel filter change on XJ6 87
Old Sep 1, 2018 | 07:08 AM
  #41
Doug's Avatar
Originally Posted by chrisleg
ALSO What is this?? And could this be causing the odd sound??? Does it need cleaning out or replacing ever??
That's the air bleed for the fuel lines....plus one of the nipples is a one-way check valve to help keep pressure in the fuel line. As far as I know it won't cause any odd noises
Old Sep 9, 2018 | 07:53 PM
  #42
chrisleg's Avatar
Hi Doug
Sorry i missed this. I didnt get an alert.
So no need to change in your opinion?
Thanks again!
Old Sep 9, 2018 | 07:55 PM
  #43
chrisleg's Avatar
Originally Posted by Andy Paine
Just did this. Sadly I was spured to do this because the deposits in the tanks killed my fuel pump, which I will replace today.
How did it go?
Did mine and was a learning curve but fun all the same and I am glad its done. One more thing off my TO DO list!
Chris
Old Sep 9, 2018 | 08:31 PM
  #44
Doug's Avatar
Hi Doug
Thanks again!
Change the fuel pump?
Not sure, I couldn't hear the noise in your video.
The pump should hum and the sound be consistent.
Sometimes they'll growl......not good. In my experience, a growling pump can soldier on for ages. Or not. There's no way of predicting. Since a dead pump will leave you stranded on the roadside it's on my "when in doubt, change it out" list (as opposed to my "Let's wait for further developments" list ).
The original Bosch pumps were incredibly robust and long-lived, IMO. But age eventually begins taking a toll.
Dirty fuel.....fine, silt-like rust, often.....will kill one quickly. Thus the rationale behind pre-filters.
Sometimes a clogged filter increases pump noise.
Old Sep 9, 2018 | 10:06 PM
  #45
chrisleg's Avatar
Good evening Doug
I stuck I some pre filters and changed over the hoses from the fuel tanks.
I got a fuel filter and changed that over 3 days ago. I also changed the 5/16?? Hose leading from the pump to the little hollow metal rail leading to the main filter. Not sure what called???
But I still get a sound that's like "put put putty put" almost like the fuel is not regular.
the only hose I havent changed yet is the one from the t junction leading to the pump itself. The 1/2 one.
Could the little fuel gate thing be an issue?? In picture attached.
although my gut feeling is that it may be the last hose to the pump
any ideas very welcome and appreciated!
Old Jun 10, 2020 | 02:59 PM
  #46
Noah's Avatar
So i received ONE of the prefilters today. No idea why they decided to send the in separate mail outs.
Anyhoo. I am guessing that the arrow should point to the fuel tank OUT line??
I've recently added these wix pre-pump fuel filters to my SIII after replacing all the fuel hoses in the trunk/boot. I came across this thread and photo and had a question. I assumed the arrow on these wix filters indicate the direction of the fuel flow and therefore should point away from the tanks and towards the crossover valve. However, no one chimed in on chrisleg's question. Am I correct? Thanks.
Old Jun 10, 2020 | 04:51 PM
  #47
kudzu's Avatar
You are correct, the arrow on any fuel filter I've ever seen is the direction of flow ( from tanks to crossover valve in this case ).
Cheers,
Brian
billwyatt83
Apr 3, 2020 02:48 PM
Wolfman01869
Apr 11, 2015 05:05 PM
bigmatt357
Aug 11, 2014 08:39 PM
plums
General Tech Help
Apr 2, 2013 07:20 AM
Adam Lueb
Oct 14, 2010 04:11 PM
