Fuel Pump Replacement Recommendations
Old Oct 13, 2013 | 04:58 PM
co74XJ6l's Avatar
Default Fuel Pump Replacement Recommendations
Greetings, all. I've been working on this 74 to get it back on the road. It's either been in the former owner's yard or in my garage for the past twenty years, so the list is long to get it roadworthy again.
One thing that came up years ago was a leaking right side tank fuel pump, the solution to that problem being to avoid using it. Now the left side started leaking last week. I've never seen a system with two pumps and a tee, only one pump and a switching valve. I'm looking for suggestions on a replacement, and am not against updating it to a switcher valve and only one pump.
Thoughts?
Old Oct 14, 2013 | 11:18 AM
co74XJ6l's Avatar
Anyone? Thoughts?
Old Oct 21, 2013 | 10:59 AM
co74XJ6l's Avatar
Thought I'd give this a bump to see if anyone has any recommendations
Old Oct 21, 2013 | 11:31 AM
Fraser Mitchell's Avatar
Is it the submerged pump ? If it's just a leak, then surely only a gasket issue. The internet shows some of these, but all used. I don't think they are available new anymore. I think the alternative is to fit an external aftermarket pump. This needs to provide fuel at low pressure as your car is carburetted.
Old Oct 22, 2013 | 09:13 AM
co74XJ6l's Avatar
No, this uses two identical pumps, one for each tank, in the spare tire well. They feed into a tee, and then on to the engine. It's clear that these pumps dried out over time, but I can't figure out whether this car came with two pumps instead of a switcher valve. Also trying to locate even one of these pumps as a replacement, or if I should replace them with aftermarket pumps. I don't mind having two pumps, even if it's not factory.
Old Oct 22, 2013 | 04:31 PM
Could you show a pic of one of the pumps, please, it might jog my memory.
Old Oct 23, 2013 | 08:32 AM
co74XJ6l's Avatar
Here's a shot of the two pumps. Hope this helps a little
Old Oct 23, 2013 | 03:32 PM
Aha, these look like the pumps that go "tick-a-tick-a-tick and were a common thing here in the UK on all cars with electric pumps. They were once made by SU Fuel Systems, but are now supplied by a company called Burlen Fuel Services, but most Jaguar suppliers sell them. They work via a solenoid that gives the ticking noise.
Fuel Pump - SU - Points type at www.rimmerbros.co.uk
How does this look: -
Attached Thumbnails Fuel Pump Replacement Recommendations-jaguar-fuel-pump.png
Old Oct 24, 2013 | 08:44 AM
co74XJ6l's Avatar
That's the pump! The fact that there's two of them still boggles my mind a bit.
I'm still trying to determine the best method of repair - keep two pumps or adapt a single pump with a switcher valve. I've sourced a pair of pumps that should work. I think I like the redundancy of two systems in place, if for no other reason than the wiring and plumbing is already there. Are these pumps powered by a relay(s)?
Old Oct 24, 2013 | 05:01 PM
Here's the fuel pumps listed by the maker, now Burlen Fuel Systems. YOU will see that there is a repair kit available. Surely worth trying ! I am not sure if they have a US agent, or ship directly. website has lots of info. Jaguar were a user of all their stuff when the SU company made the stuff.
Fuel pumps for AUD 647 for Jaguar 1946 onwards XJ6 4235 cc - SU Carburetters - SU Carburetters
And a bit of history
History - SU Carburetters
Of course it is all EFI now, carbs are history unless you have a carburettor car, of course !! My MG Midget as twin SUs, but pump is mechanical, not electric.
Old Nov 6, 2014 | 09:41 AM
314jjwalls's Avatar
Frasier,
Thank you very much for your insight and information. I too have a xj6 with fuel pump issues. I am choosing to install one pump and connect both tanks via the tee provided. A simple solution. My jag is powered by a chevy 300hp, 350 with th350 with 3:31 rear end. A nice running reliable ride. Very smooth and with more power. Thank you again for your info.
Jack Walls
toronadomike
Jan 22, 2026 10:13 PM
fast40driver
Apr 19, 2024 07:24 AM
Russ Graber
Feb 23, 2019 11:59 AM
convincor
Sep 3, 2015 08:03 PM
bluerdg
Sep 1, 2015 08:07 AM
