Hard Press On Accelerator Engine Goes Off
Old Apr 24, 2020 | 09:28 AM
mikega's Avatar
Default Hard Press On Accelerator, Engine Goes Off
Hello,
I have also notice that while driving, whenever i hard press on the 85 Jag S3 accelerator then the engine goes off in the middle of the road unless i just put my foot in the paddle then the car advances the acceleration by itself.
What could be wrong and what should be done to fix this trouble?
Mike
Old Apr 24, 2020 | 10:20 AM
Darrenmb's Avatar
Veteran: Navy
Could be anything from clogged fuel filter to a vacuum leak. With numerous things in between, at a minimum i would remove filter and shake it, see what comes out, and check all vac lines and elbows in intact tract..
Old Apr 24, 2020 | 11:43 AM
JagCad's Avatar
As I read the post., Mike reports an engine flat spot on hard throttle But, is Ok if the throttle is applied slowly
1. fuel starvation!
2. Engine vacuum goes away, timing now off !
3. Bad electrical connection somewhere. resulting in weak ignition spark
Carl
Old Apr 24, 2020 | 01:03 PM
Jose's Avatar
I guess we are all understanding something diferent.
Sounds to me like a sticking accelerator cable.
Lycaon
Feb 27, 2023 12:11 PM
Randomized channel
Sep 9, 2018 02:05 PM
xjfourty
Feb 19, 2018 03:02 PM
pearcec85
Oct 12, 2017 11:02 AM
chef1969
XJ40 ( XJ81 )
May 16, 2010 08:26 PM
