headlights only work on high beam
Old Jul 25, 2013 | 10:14 PM
82jaguarxj6's Avatar
Default headlights only work on high beam
I was working on the jag the other day, was replacing a headlight. turns out it didn't need it, the wiring was separated. fixed that and turned on the headlights, nothing. then I went to the high beams and all 4 lit up, came back a little bit later and did it again. this time they worked but had no dash lights. went to town for some jeep parts and tried again, this time dash lights but again, no headlights unless they are on high beam. what do you guys thing is the culprit this time? ive changed relays and checked fuses. didn't change a thing. thanks in advance
Old Jul 25, 2013 | 11:00 PM
Doug's Avatar
I think you might have a couple different problems. Not sure.
Corroded fuses and fuse clips, poor grounds, and nasty bullet connectors often play hell with the lights. As often as not a thorough cleaning of all the above brings everything back to life
This has a few details
Headlamp Circuit Checklist
The panels lights might be a different issue....possibly related to the headlight switch or the panel rheostat. I suggests getting the headlights working and go from there
Old Jul 26, 2013 | 12:45 AM
OliverB's Avatar
I strongly suggest tightening, cleaning and/or replacing all fuses in front (engine bay) fuse box. Cured all my headlight problems.
Old Jul 26, 2013 | 11:06 PM
replaced all the fuses today and cleaned the contact points, didn't change anything. tomorrow ill clean the connectors on the underside of the fuse box, hopefully that fixes the issue
Old Jul 27, 2013 | 03:00 PM
JagCad's Avatar
Yeah, I did the same thing. Before the jaguar, the solution was always burnt seal beam. Replace same fixed!!! So, I replaced the right outboard when it went dark. No luck. Messed with connections and there was light. Oh, well, the new sealbeam is brighter and I have a spare!!!
Then, odd results on low high selection. Random light ups!!! Cleaned some more stuff. It was opnly when I removed the fuse box from it's holder and scrubbed the underside with a brush and cleaner did symetry and precise obeyance to command result!!
Twas a mess under there!!
Carl
Old Jul 28, 2013 | 02:35 PM
Well cleaned the box and it solved the issue, everything works as it should now. Thanks for pointing me toward the problem!
Old Jul 28, 2013 | 03:04 PM
doghead08's Avatar
good to hear you fixed your problem.
ive found that some TLC is the most common cure for these types issues.
philwarner
Oct 4, 2024 01:37 PM
JakeXKE
E type ( XK-E )
Jul 6, 2021 06:49 PM
Russ Graber
Feb 23, 2019 11:59 AM
laserguy
Sep 3, 2015 02:02 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
