Horn Steering Column Trigger
Old Apr 5, 2025 | 09:13 AM
Thank you, Aden!
Had to be a bearing in there somewhere. Looks a bit dry too.
Old Apr 6, 2025 | 07:03 AM
adenshillito's Avatar
the offending spring
Old Apr 6, 2025 | 09:32 AM
Aww, it looks so, Innocent!
How could a cute little thing like that be the cause of all this Drama?!
Old Apr 6, 2025 | 09:01 PM
redtriangle's Avatar
Excellent work, venturing into the deep dark mysterious world on XJ6 steering columns!
Bearings need a clean and relube, as I suspected.
No part # for that pesky little spring it seems, maybe a generic one of same size will suffice.
However once re-assembled, you should be able to test the electrical continuity btw the horn=push end of the rod & ground contact (copper ring) on the inner column.
Apologies for not mentioning the plastic bush for the spring is a split one. I forgot about that.
Cheers & beers.
Pete.
Old Apr 7, 2025 | 09:26 AM
Andy T.'s Avatar
Hooray! Somebody finally spelled COPPER correctly
Old Apr 8, 2025 | 03:42 AM
And copper is easy to solder (soul-der, not sodder}
Old Apr 8, 2025 | 12:46 PM
Greg in France's Avatar
Solder not SOUL-der ??!!
Old Apr 9, 2025 | 04:48 AM
  #28
how strange i never noticed. so often too. it was my new years resolution, to never spell it right again. not to be confused with a Mini Cooper.
Old Apr 9, 2025 | 04:58 AM
cheers. the spring wasn't split when i tried to take it out it broken on extraction.
reassembled today but i don't have the means to compress and seal the spring down and reapply the circip.
here are the images any way.
rod
rod
rod
rod
rod
rod
COPPER ring
COPPER ring
rod
rod
helper
helper
helper
helper
Old Apr 10, 2025 | 04:12 AM
  #30
[QUOTE=adenshillito;2836472 i don't have the means to compress and seal the spring down and reapply the circlip.[/QUOTE]
Replacing the circle is a bit tricky, you may need a helper whilst someone compresses the spring.
Just make sure the inner shaft is pushed completely towards the bottom end. Maybe holding the outer column upright in a vise will assist.
Keep at it, your'e nearly there!
Old Apr 15, 2025 | 09:25 PM
  #31
the big outer circlip has lost shape slightly..... can we fix it?
bigger daddy circlip
Old Apr 16, 2025 | 05:48 AM
  #32
Maybe gently close it up in a vise?
Doesn't look too bad to me.
Pete
Old Apr 16, 2025 | 04:28 PM
  #33
the little guard plate that is held on my three screws doesnt actually seem to prevent the column section falling through but maybe it doesnt need to ? when the circlip is back in place it will stay put but then what is the purpose of the semi cirlce guard plate then.
Old Apr 17, 2025 | 03:39 AM
  #34
Part of the adjustable column mechanism when assembled? Not sure. Sorry.
Old Nov 16, 2025 | 09:25 AM
  #35
jdere31's Avatar
Originally Posted by redtriangle
Yes, that probe (brass rod) can be an annoying little tosser. Mine was shorting on the inner column such that when turning the steering wheel, the horn sounded.
Basically, it made the car undriveable!
Redtriangle, I'm guessing one can't tell what's happening at the end of the brass rod unless the whole steering column is removed and taken apart.
Old Nov 17, 2025 | 05:11 AM
  #36
Pretty much, unfortunately.
What are your symptoms? No horn at all, or horn activating whilst turning your steering wheel?
It is worth dismantling it because the spring that contacts the internal column copper ring is likely to be the problem (broken or rusted up).
It needs lubrication (copper grease) along with the upper and lower conical bearings that are normally unserviceable.
The shims at the base of the column (after the circlip) determine the pre-load on the bearings, so don't lose or forget to replace them.
Old Nov 21, 2025 | 08:28 PM
  #37
jdere31's Avatar
Horn turning on intermittently. Just can't trust driving car with horn suddenly starts going off.
Old Nov 22, 2025 | 09:17 PM
  #38
Yep. Same problem I had.
Seems there is a short circuit at the point where the split plastic collar fits over the inner column secured by the brass/copper slip ring that makes contact with external spring contact fixed to the outer column.
This contact is permanently "live" with 12 volts.
Unfortunately, you will need to dismantle the column as described before. This means removing the whole column assembly from the car. Beware of yet more shims where the outer column is bolted to the cross-member near the dashboard.
Sorry to be the bearer of bad news.
The good news is time spent fixing it means less time at the pub, the local betting shop wasting money on slow horses. or otherwise chasing fast women
oxendine
Oct 17, 2022 10:26 AM
brinny
Jul 13, 2020 02:13 PM
Robbo9
Feb 13, 2019 03:34 PM
51rover
Jul 20, 2018 02:42 PM
monqc
XJ40 ( XJ81 )
Sep 24, 2016 08:07 PM
