Ignition Wire Group
Old Aug 14, 2021 | 01:33 AM
adenshillito's Avatar
Default Ignition Wire Group
Caping some plastic bezels back on around the steering wheel, fairly sure the ignition purple/black wire has a ready made partner in the purple/black of the ignition wire bundle but i have a single loose black wire hanging but going no place. i also have a few loose wires in the foot well at right which i think are related to the door open/close triggers but not certain. Any thoughts?
the purple from the ignition seems to have a ready partner in another purple/black plug beside it but I also have a loose black one ...?
These guys drop down from beside the fan near the foot pedals without clear ID. related to door open/close maybe
Old Aug 14, 2021 | 05:19 AM
No idea on the foot pedal wires.
BUT
Check that stray Black wire carefully. It MAY NOT be a wire, it may be the Fibre Optic strand for the bezel.
Old Aug 14, 2021 | 05:50 AM
All the fibre-optic was gone who i acquired it, but i'll double check to be sure.
Old Aug 14, 2021 | 12:54 PM
LT1 jaguar's Avatar
Active Streak: 60 Days
Your first pic shows a Purple/Black wire with female connector and the wire with the male connector looks like a Black/Purple. I don't know that the color code would change mid-stream like that.
I think the black "wire" is really a wire. Here is a picture of a F.O.
Dave
Old Aug 16, 2021 | 11:48 PM
So what exactly is the copper critter here pictured and does anything clip or plug onto it? it seems to determine the position of the steering column like a primitive sensor.
copper critter under steering column
Old Aug 17, 2021 | 05:57 AM
o1xjr's Avatar
That copper critter is the connection for the horn. Can’t remember if it’s the earth or the black/purple.(fairly sure a male bullet connector on a black wire pushed into it.
One black and purple wire is for the horn, the other is redundant on your car. It is for the headlight buzzer in the USA market.
If you have a Haines manual check out the US wiring diagram.
Old Aug 17, 2021 | 06:59 AM
yachtmanbuttson's Avatar
And... speaking from experience - it needs to be cleaned periodically and apply a dab of dielectric grease with a Q tip. I only see one in the pic above; my 1975 XJ6C has two of them. Both of them accessable by just taking the upper knee scuttle off. I stick a blue shop rag into the hole and rotate the steering wheel to clean all the way around the "armature" hub part. And be careful to also clean the copper (or brass) "brush". You can see in the above pic this one is due.
Symptoms - horn starts going off intermittently when driving (very annoying and embarrassing - it may illicit the one-finger salute from other drivers that think you are honking at them for their self-perceived excellent driving). And... the steering column starts making this weird "scratching/rubbing" sound that drives you crazy.
Old Aug 17, 2021 | 07:02 AM
Forgot to mention - until you fix this, and the horn is driving everyone nuts, remove the horn fuse. Mine is located on the fire wall in the engine compartment just inboard the battery in an
in-line pop-apart twist turn fuse holder.
Old Aug 17, 2021 | 07:16 AM
like this image from elsewhere on the forum?
Old Aug 17, 2021 | 07:25 AM
Yup! Those be them. You'll love working with those itty bitty nuts and screws!
Old Aug 17, 2021 | 05:38 PM
So one wires actually plugs INTO the tail of the copper thing. think there might be the remnant head of an old plug in my one maybe, or a silver mount plug its hard to tell
Old Aug 18, 2021 | 05:51 AM
o1xjr's Avatar
yep. That is a picture of under my column taken quite a few years ago.
Colfod
E type ( XK-E )
May 11, 2018 06:13 AM
orangeblossom
Sep 20, 2017 04:50 AM
northwestjagxj6
Mar 11, 2015 05:45 PM
Jagxjs
Jan 20, 2013 07:25 PM
sempaipaul
Jan 14, 2007 02:25 PM
