injector specs
Old Jul 25, 2015 | 12:15 PM
amaezing's Avatar
Default injector specs
Anyone know what the injector specs are? Volts and resistance.
Old Jul 25, 2015 | 12:38 PM
amaezing's Avatar
Volts was easy. 12. But i still don't know what the resistance is suppose to be.
Old Jul 26, 2015 | 05:56 AM
amaezing's Avatar
I couldn't find what they are suppose to be listed anywhere, but mine where all 3.6 straight accross.
Old Jul 27, 2015 | 07:08 AM
amaezing's Avatar
Helped a little but not what I was hoping for. cleaned all the injectors, replaced hoses and o rings, adjusted throttle plate. still not firing right up. I think it would be real nice if the pump would prime the system before engaging the stater, but any input to help start would be helpful. I also did cap, rotor,and plugs. Maybe out of time? I don't have a timing light anymore but I guess if I had to I could get a new one, but something is telling me that it is O.K. Could be wishful thinking though.
Old Jul 27, 2015 | 07:21 AM
Doug's Avatar
I can't remember the specifics. Long cranking time, perhaps? If so, how long?
If everything is in good order the pump will pressurize the fuel rail in about 2 or 3 seconds.
Have you tried the 'put it in drive and turn the key to start' trick? Did it make any difference ?
Have you checked fuel pressure?
You could just experiment by turning the distributor a few degrees just to see if anything changes
Old Jul 27, 2015 | 07:37 AM
amaezing's Avatar
It cranks for about 5-10 seconds.
I don't quite understand the putting it in D thing. do I just put it in drive with the key in the on position for a couple secs. first? The pump is new and putting out good pressure. I'll give it a try.
Old Jul 27, 2015 | 07:48 AM
Doug's Avatar
Put it in "D" (or anything except "P" or "N") and turn the key to "Start" for a few seconds. This operates the fuel pump without operating the starter, thus pressurizing the fuel system.
Now try starting normally.
Any difference?
A million years ago I had a problem with long cranking on my Series III. Very long story short, a new battery solved the problem.
Make sure the battery is 100% charged and the connections are good.
Old Jul 27, 2015 | 07:59 AM
amaezing's Avatar
Any difference?
Well it made a difference. Took 4 seconds that way. I will have to warm it up to see if there is more of a difference after temps go up. there has always been a difference then.
I've always wondered about the battery. I know the newer jags are very picky about CCA and CA, are these also. What is the correct amps?
Old Jul 27, 2015 | 08:35 AM
Doug's Avatar
I can't remember the spec but it's nothing unusual ....750 CCA or such.
An idea might be to charge the battery overnight so that it is *really really* fully charged for the next morning. Then try starting. If it starts much more easily, there's a clue.
Also important, naturally, is voltage drop at the junction posts on the firewall....or anywhere else.....and good solid ground points, etc.
Might also wanna check for voltage drop at the *fuel pump*. If the pump is starving for voltage it won't have as much oomph, obviously.
Old Jul 27, 2015 | 09:00 AM
amaezing's Avatar
All good ideas! Ill do that later today. gotta get going for the day. Thanks doug as always, Great advice!
Pringleblue
Jan 12, 2021 11:42 PM
jospolice
Oct 2, 2015 07:16 PM
reb1999
Sep 26, 2015 08:41 AM
SD96XJ6L
Sep 25, 2015 10:53 PM
