I've been hosed
Old Aug 26, 2024 | 03:52 PM
jbellK75's Avatar
Default I've been hosed
Never seen this in a car before. '87 xj6 only in the left side fuel tank. Any idea why a rubber hose is in my filler? I gave it a little tug and it feels attached to something.
Old Aug 26, 2024 | 05:30 PM
jal1234's Avatar
Maybe the tank on that side has a leak, and they jammed a hose in there to stop anyone from trying to fill that tank. Is the car new to you?
Jon
Old Aug 27, 2024 | 09:52 AM
jbellK75's Avatar
Yes, I just bought the car last week. I'm trying to get in touch with the previous owner but haven't heard back yet. Your suggestion of the tank leaking makes sense. I am new to Jag and thought this might be some kind of breather. Thanks...........Jack.
Old Aug 27, 2024 | 11:36 AM
LT1 jaguar's Avatar
Active Streak: 60 Days
Someone tried to siphon gas out of your tank and their hose got caught on the anti-siphon flapper just under the filler neck. They just cut it off and left it. If you use a thin pick or screwdriver to hold the flapper open (it's spring loaded), you can pull the hose out.
Dave
Old Aug 27, 2024 | 11:50 AM
jbellK75's Avatar
Ahhh, now that makes even more sense. Maybe I'll just leave it there as a quick connect should I need to siphon a gallon or two for the lawnmower. Don't you just hate it when your hose gets caught in a flapper?
post script, I think you are right. I did as you suggested and retrieved the hose with some judicious twisting and turning. Hope I didn't upset the level sensor. They did use proper fuel line so I'll give them credit for that. Your Hershey bar is in the mail. Thanks..........Jack. I'm getting this beast sorted out bit by bit, one lo beam, one hi beam, one fog light, dashboard brake light on, horn steering column ground contact, horn fuse holder (duct taped together), steering column support bracket bolt and now the fuel tank filler.
Old Aug 28, 2024 | 01:18 AM
LT1 jaguar's Avatar
Good start, keep at it.
Dave
Jeffkrell
Dec 22, 2024 01:45 PM
michaelgilbert
Jan 23, 2024 03:18 AM
newtojags
Apr 7, 2023 06:35 AM
SamtheSham
Apr 13, 2021 12:16 PM
944xjs
Mar 8, 2017 09:40 PM
